C452 CQ
  • kingarthur
    • 1375
    [CQ] C452 CQ
    Hi everyone...got a C452 that produces a dirty mark, like a scuff on the first copy/print out only, about 1 cm from lead edge....but only when copying/printing black, it's fine when copying/printing in colour, i've tried another K drum unit, i've cleaned the entrance to the fuser, i've even blocked the entrance to the fuser to elminate that part of the m/c, i'm thinking it must be a dev or dev unit issue, has anyone else had a problem...
    cheers
  • PeterG
    • Jul 2008
    • 177
    Re: C452 CQ
    That's ringing a bell. I think it was the belt. But I wouldn't trust a 55 year old hard living fossil's memory.
    • fornerm
      • 82
      Re: C452 CQ
      Scan and post a test pattern, so we can see..........
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Re: C452 CQ
        its the belt
        the cleaning brush leaves dirty marks on the first page near the leading edge of all print runs, but not subsequent pages of the same print run. It must be replaced. (transfer belt unit)
        • Gaffers01
          • May 2011
          • 335
          Re: C452 CQ
          I have had this problem on 2 machines in the same office, it is the transfer belt
          BUT from my experiance the problem will comeback after awhile.
          I havent ever totally got rid of the problem, i just replace belt and then wait a few months for the call to come back in.
          • JustManuals
            • Jan 2006
            • 9838
            Re: C452 CQ
            King - If you want the SM and PM just message me and I'll send it along at no charge
            Paul
            • Spidula
              Konica Minolta Technician
              • 83
              Re: C452 CQ
              Vac out the cleaner section. Keeps it going for a while till the next time. A lot cheaper than changing the belt every time
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                Re: C452 CQ
                certain environments will have a repeat issue and the belt wont last its full life. I'm not sure what causes it but it seems more prevalent on high coverage customers.
                Its actually more common than you think, most customers in my experience don't notice it, so i don't go out of my way to point it out to them.
                • kingarthur
                  • 1375
                  Re: C452 CQ
                  thanks everyone...i'm back at work tomorrow, cant scan an image....cos it wont show up on scan...unfortunately the customer has noticed on both the m/c,s we have the problem on....thanks for the offer Paul...but I've already got them...
                  • PeterG
                    • Jul 2008
                    • 177
                    Re: C452 CQ
                    It seems my feeble memory was correct in this instance.
                    • David Morrison
                      Digital Tech II
                      • Feb 2010
                      • 43
                      Re: C452 CQ
                      cheers
                      I'm having the same problem. Did you find a solution?
                      (never mind... Read the other posts... I will try the transfer belt or clean the cleaning section)
                      Last edited by David Morrison; 07-16-2013, 04:31 PM. Reason: read further down for answers
                      • HoonBoy
                        • May 2011
                        • 130
                        Re: C452 CQ
                        The solution for this problem is to adjust the Transfer cleaning bias(plus power adjustment) to -5.
                        Try it and save yourself a few transfer belts...
