4 series transfer belt clicking
  • JR2ALTA
    • Feb 2010
    • 2033
    [CQ] 4 series transfer belt clicking
    Loud, but not horrific, clicking from T-belt.
    Less than 20k,.first vacuumed good for a week, then replaced good for a month, now back again.
    Hoping it's not more Konica toner rocks
    Anyone delt with this? Thanks
    • 23009
    Re: 4 series transfer belt clicking
    Have you looked at the transfer belt drive coupler? The C451/500 had problems with that drive coupler. If I remember correctly you can pull the left side cover and watch the drive coupler while it runs. =^..^=
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      which 4 series ?
      224 - 554 share nothing in common engine wise to the 654 - 754, may as well be a ricoh.
      • JR2ALTA
        • Feb 2010
        • 2033
        Originally posted by EarthKmTech
        which 4 series ?
        224e
        gave the best look i could first time it happened, covers off etc. seemed to be within the t-belt, almost confirmed by the vacuum/replacement
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          sounds like the same issue that afflicted the c360 series, whereby the waste toner chute to the box blocked up and caused toner compaction in the cleaning section and then clicking of the drive gear as it failed to turn.
          that issue is environmental and if its what your having, it will be the same.
          • Hansoon
            • Sep 2007
            • 3389
            Heath? Humidity? Both?
            Hans
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              I've nfi what causes it, but it only happens in certain locations. KM came out with some BS about it being carpet fibers settling on the transfer belt, but most of the places i experienced it didnt even have carpet
              I know that excessive low power mode time outs aggravate the problem too.
              • kingarthur
                • 1369
                There's a TAD from KM, no TAGB1300560EN
                It's due to the waste toner pipe
                • Hansoon
                  • Sep 2007
                  • 3389
                  Anybody having this bulletin for me please?
                  Hans
                  • kingarthur
                    • 1369
                    The bulletin isn't opening, but they have changed the waste toner pipe & seal,due to the seal becoming detached, new part nos are, the bulletin applies to all of the range
                    A0ED363300 A0ED363301 Seal
                    A0EDF36000 A0EDF36001 Waste Toner Pipe
                    • Hansoon
                      • Sep 2007
                      • 3389
                      Thanks!
                      Hans
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        I've never had the seal detached, on the ones I've had (numerous) its been because the waste toner was all sticky and clogged half way up the waste toner pipe. If they have redesigned the pipe to be less restrictive its definitely a good thing though.
