Recently bought a used Konica Bizhub C451, and the scanner/fax button seems to have been disabled. There are no error codes, and the machine will still copy. The machine basically beeps twice if the scanner/fax button is pressed and then behaves like nothing has happened. Any thoughts?
Scan/Fax Disabled Bizhub C451
andcarne
Re: Scan/Fax Disabled Bizhub C451
I'm encountering the same issue on a used C253 that was recently bought. This machine does not have a HDD. My understanding is that it should at least be able to Fax without a HDD. Is that not correct?Comment
Both the C253 and C451 have Copy / Print / Scan out of the box. Updating the firmware is a good start, calling in a service tech to fix your problem is an even better idea as there maybe more happening.Please don't ask me for firmware or service manuals as refusal often offends.Comment
weldlamrini
Bizhub C451 Scan/Fax Bouton Problem (desactivated) / Scan/Fax Disabled Bizhub C451Comment
All,
Thank you for helping fellow techs.
I have same situation.. Checked the HDD sees to be fine and also formatted the HDD.
Seems like some one played with this machine. checked all connections seems to be good.
Still I am getting the message:
Following functions cannot be used
because the scanner is not available.
: copy/scan/fax
Note: I checked the HDD also traced the connector from ADF to the place it connects on the main board.
Also tried to replace the ADF from a good working machine. Nothing helps.
Any help to steer me in the right direction is appreciated.
Thank you in advance
Regards
ThendralComment
In a situation like this, some external event has caused the machine to detect a problem that affects copy/scan/fax. It possibly could be the HDD, maybe it was removed w/o unsetting it, but it looks more like you have a scanning issue which would affect copy/scan/fax..If you can print then I would think this is the issue. You need to enter service mode and determine what then current failure codes are. EComment
All,
: copy/scan/fax
Regards
ThendralComment
All,
: copy/scan/fax
Regards
ThendralIf you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
thendral, assuming no error codes are present.
SCANNER NOT AVAILABLE message on the operation panel when pressing the Fax/Scan key.
CAUSE: The scanner is isolated.
SOLUTION: To activate the scanner, perform the following:
1. Enter Tech Rep Mode.
2. Select System 1.
3. Select Trouble Isolation.
4. Press the number 3 tab.
5. Select the scanner and change to UNSET.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
Could just run a trouble reset.
If the message happens again there is a problem with the scanner itself.We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
