Scan/Fax Disabled Bizhub C451
  • thinkdenver
    • Jun 2025
    Recently bought a used Konica Bizhub C451, and the scanner/fax button seems to have been disabled. There are no error codes, and the machine will still copy. The machine basically beeps twice if the scanner/fax button is pressed and then behaves like nothing has happened. Any thoughts?
  • wseyller
    • Sep 2012
    • 1129
    Re: Scan/Fax Disabled Bizhub C451
    Does it have a hard drive and is enabled?
    • andcarne
      I'm encountering the same issue on a used C253 that was recently bought. This machine does not have a HDD. My understanding is that it should at least be able to Fax without a HDD. Is that not correct?
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        I had a c451 we bought used do the same thing...updated FW and has worked fine after that.
        "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
        • TheOwl
          • Nov 2008
          • 1732
          Does the device actually have a fax kit installed in the machine though?
          Both the C253 and C451 have Copy / Print / Scan out of the box. Updating the firmware is a good start, calling in a service tech to fix your problem is an even better idea as there maybe more happening.
          • weldlamrini
            Bizhub C451 Scan/Fax Bouton Problem (desactivated) / Scan/Fax Disabled Bizhub C451
            • thendral
              • Mar 2011
              • 82
              All,
              Thank you for helping fellow techs.
              I have same situation.. Checked the HDD sees to be fine and also formatted the HDD.
              Seems like some one played with this machine. checked all connections seems to be good.
              Still I am getting the message:
              Following functions cannot be used
              because the scanner is not available.
              : copy/scan/fax
              Note: I checked the HDD also traced the connector from ADF to the place it connects on the main board.
              Also tried to replace the ADF from a good working machine. Nothing helps.
              Any help to steer me in the right direction is appreciated.
              Thank you in advance
              Regards
              Thendral
              • emujo2
                • Mar 2017
                • 1579
                In a situation like this, some external event has caused the machine to detect a problem that affects copy/scan/fax. It possibly could be the HDD, maybe it was removed w/o unsetting it, but it looks more like you have a scanning issue which would affect copy/scan/fax..If you can print then I would think this is the issue. You need to enter service mode and determine what then current failure codes are. E
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4646
                  Originally posted by thendral
                  All,
                  : copy/scan/fax
                  Regards
                  Thendral
                  Did you go into service mode to see if fax was "set" ?
                    • 22999
                    All,
                    : copy/scan/fax
                    Regards
                    Thendral
                    You should check that the scanner is not errored out or isolated. Check error codes and jam codes. If you can print do a management report. =^..^=
                    • tsbservice
                      Field tech
                      • 7986
                      thendral, assuming no error codes are present.
                      SCANNER NOT AVAILABLE message on the operation panel when pressing the Fax/Scan key.
                      CAUSE: The scanner is isolated.
                      SOLUTION: To activate the scanner, perform the following:
                      1. Enter Tech Rep Mode.
                      2. Select System 1.
                      3. Select Trouble Isolation.
                      4. Press the number 3 tab.
                      5. Select the scanner and change to UNSET.
                      • Synthohol
                        Certified Konica Expert
                        • Mar 2016
                        • 5808
                        Could just run a trouble reset.
                        If the message happens again there is a problem with the scanner itself.
                        • thendral
                          • Mar 2011
                          • 82
                          Thanks to all of you copyman, blackcat4866, tsbservice & Synthohol.
                          I am going to the customer today I will try all your suggestions and update you.
