Only copies of shooting, sometimes doing a faint copy malfunction middle. (Copy samples are attached.)
Kyocera km-6030 light copy problem (print no problem)
Re: Kyocera km-6030 light copy problem (print no problem)
So it's ok on prints? Then you are looking at the optical section. What have you done so far? -
What is the feed direction LTR or LTR-R (A4 or A4-R)?
I'm going to take a WAG that it fed LTR-R/A4-R and it could happen on prints, just that it's intermittent and you saw the copies first.
It looks to me like a charge contact issue. It could be the developer bias contact or the transfer charge contact. You can use conductive grease on the transfer charge contact, but cannot use conductive grease on the developer bias contact.
A search might have brought you to this thread:
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
=^..^=Comment
feed direction is A4,not reduction.I changed the ccd card.Last edited by alpertevfik; 09-04-2016, 12:39 PM.Comment
the problem continues.Does anyone ever encountered this problem?
