Kyocera 3051ci with colored lines (samples included)
  • giddyupngo
    • Oct 2014
    • 109
    Hi, this machine has under 70K on the meter, evenly divided between color and B/W. Three different techs have been here, all have been unable to reproduce error onsite. This makes it difficult to replace parts because it is all a shot in the dark. This last happened late in a run of 75 prints. I have run 100 of the same file and have not seen it. I checked the voltage at the wall, electrical ground is good. Has anyone seen this and what worked for you? Thanks!Samples of lines on 3051ci.pdf
  • giddyupngo
    • Oct 2014
    • 109
    Re: Kyocera 3051ci with colored lines (samples included)
    Has latest firmware too, 5.105
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1888
      I would start by cleaning & lubing the drum grounds in the front toner hopper unit. Blackcat & I have had discussions at length regarding this. He had one that was losing black. Mine was a 3050ci that was losing magenta. That's what yours looks like it's missing to me. It usually happens to the front frame side.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • giddyupngo
        • Oct 2014
        • 109
        Thanks Tony,
        Voids showed up on the grey bar in U089, so I replaced the black developer and it is now working. I will keep your advice in mind if it comes back. Thanks!
          • 23009
          Originally posted by giddyupngo
          Thanks Tony,
          My suggestion is to clean an re-grease the drum ground before it depletes another developing unit. My machine was dumping developer such that the symptoms were back within a week. How many developing units would you like to install? =^..^=
          • tmaged
            • Oct 2008
            • 1888
            Actually I enlarged it & it looks to me like it's missing cyan out of the samples you posted. Shouldn't have anything to do with the black DV unit.
            Hope that helps !
            -Tony
            www.dtios.com
              • 23009
              I beg to differ tmaged. I do have the advantage of having good scans and some additional tools at my disposal. In the second example it's only magenta that he's losing. In the third example all colors are fading out. =^..^=
              Interestingly, the CMYK colors do not fade out at equal rates through each streak. Sometimes magenta fades first, sometimes cyan fades first. Since there is no yellow, I can't really evaluate yellow. Black fades the least.
              I think cyan may be overtoning, dumping splotches of toner unexpectedly. Maybe it's just the endusers choice of colors, but there are almost no yellow pixels in this document anywhere. If you have a shorting developing bias, it's probably on yellow. Try printing the test document attached. I'll be interested to see how yellow prints.
              This sample is from the last page of the PDF document, enlarged to 800%, then ColorPic breakdown of the colors.
              • Tonerkiller
                • Oct 2012
                • 668
                That sample is missing cyan
                • giddyupngo
                  • Oct 2014
                  • 109
                  I have a call to go back to this same machine, don't know if it is the same issue. Just in case how do you clean and lube the drum grounds on the inner unit?
                  Thanks!
                  • tmaged
                    • Oct 2008
                    • 1888
                    Pull the grey toner hooper unit off the front of the machine. The drum shafts go all the way through the drum & ground inside the bearings. Check bearings & use conductive grease on the shaft ends.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    • giddyupngo
                      • Oct 2014
                      • 109
                      Thanks Tony,
                      Arrived, ran Black Cats test before doing anything, attaching more recent image samples
                      Had to use High Compression PDF for Black Cats test, File uploader wouldn't take a 12MB file, though it should be within the limit.
                      doc00994120161006131825.pdf
                      • tmaged
                        • Oct 2008
                        • 1888
                        Do you think the drum ground was the cause of the problems ?
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        • giddyupngo
                          • Oct 2014
                          • 109
                          Ended up replacing the magenta developer based on the recent image defects. Cleaned the drum grounds, bearings looked good. Did not re-lube as was not sure which grease to use. What do you use for conductive grease Tony? No evidence of image defect today. Will wait and see if problem returns.
                            • 23009
                            Exactly, and watch for rusty dust. Photos:
                            So you removed all the grease and left it unlubricated? Does that seem like a good idea?
                            • giddyupngo
                              • Oct 2014
                              • 109
                              I didn't remove all the grease, just removed from drum shafts, the inner unit side still had grease on it. I was worried I didn't have the right grease, and was trying to balance conflicting advice between the forum and from co-workers. I looked into it and it seems very few greases are actually conductive, they just protect the connection from oxidization. Some have metal powder in them but sticking an ohmmeter in most greases will show "open circuit". I have lubriplate 930-AA multipurpose grease. This is the article I read. HF Nets in Hawaii
                              You are right, It should be re-lubed with something. Thanks for the pictures, there are no signs of rust or dumped developer on my machine.
