Charge rollers...
  • Geo
    • 662
    Charge rollers...
    Well... so much for the new and improved charger rollers....310 K with measles...Ohh Joy.
    Cheers and Happy New Year to all.
    • 22999
    Re: Charge rollers...
    This is a MC-8705 with one of those lumps biopsied. Note how the rubber is burned/absent from the surface of the metal core, but not through to the surface where the lump is. Anecdotally, this is caused by corrosion of the surface of the metal core.
    • JR2ALTA
      • Feb 2010
      • 2031
      Was the update designed for the bumps or for lines?
      • Geo
        • 662
        One would think both issues were solved.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1870
          Yep, just replaced one on a 6052ci for bumps. It really takes 5-6 years to resolve this ?
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • daveh12
            • Jul 2012
            • 157
            Great and i thought my troubles were over.
            • Tonerkiller
              • Oct 2012
              • 668
              What is even worst is that they are back ordered. Kyocera needs to get there shit together.
              • Eresources
                • Nov 2011
                • 37
                In Australia we've been told to use MC-8720 charge rollers in place of the MC-8705. Too early to tell but they seem to last longer.
                They changed the foam/felt cleaning roller underneath for a spiraled foam cleaning roller.
                  • 22999
                  Like so:
                  • Eresources
                    • Nov 2011
                    • 37
                    Yeah that's the one. I know they look different but that's what they told us use.
                    • Luther
                      • May 2006
                      • 682
                      Just changed an MC-8720 on an 8052ci for lines, i cleaned it and the lines came back in 50 copies machine has 263k in color,had to replace it with another 8720 it was the cyan, i checked the others and they all seemed fine had faint lines on the rollers but didnt show on copies im hoping its just an anomaly..but i fear the worse
                        • 22999
                        You mean that you fear nothing has changed. I suspect that you are correct.
                        I also suspect that it's a patent issue. All the really effective designs are already patented, and Kyocera would have to pay a licensing fee to use those designs. =^..^=
                        • tmaged
                          • Oct 2008
                          • 1870
                          But the charge rollers in the 250ci-500ci didn't have near the problems. The firmer material seemed to last much better IMO.
                          Hope that helps !
                          -Tony
                          www.dtios.com
                          • Tonerkiller
                            • Oct 2012
                            • 668
                            I just wish we could get them. We have had charge rollers for 4550ci ordered for two weeks. They are on back order. I am not sure when they will be in.
                            • tmaged
                              • Oct 2008
                              • 1870
                              We just got a bunch of MC8720's in yesterday. They had been on B.O.
                              Hope that helps !
                              -Tony
                              www.dtios.com
