This is a MC-8705 with one of those lumps biopsied. Note how the rubber is burned/absent from the surface of the metal core, but not through to the surface where the lump is. Anecdotally, this is caused by corrosion of the surface of the metal core.
Just changed an MC-8720 on an 8052ci for lines, i cleaned it and the lines came back in 50 copies machine has 263k in color,had to replace it with another 8720 it was the cyan, i checked the others and they all seemed fine had faint lines on the rollers but didnt show on copies im hoping its just an anomaly..but i fear the worse
You mean that you fear nothing has changed. I suspect that you are correct.
I also suspect that it's a patent issue. All the really effective designs are already patented, and Kyocera would have to pay a licensing fee to use those designs. =^..^=
But the charge rollers in the 250ci-500ci didn't have near the problems. The firmer material seemed to last much better IMO.
I just wish we could get them. We have had charge rollers for 4550ci ordered for two weeks. They are on back order. I am not sure when they will be in.
We just got a bunch of MC8720's in yesterday. They had been on B.O.
