8001i J42xx
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    8001i J42xx
    I've had about 5 different 8001i's (latest firmware) give me this jam code 42xx at different times. When it occurs, removing the paper will just jam again until power is cycled. Even opening the door, doesn't stop the exit motor from running continuously in reverse after the jam is indicated. I slow-mo videoed it to verify that's what was happening. Curious if anyone has seen this, or has done anything to prevent it ?
    Thanks !
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  • Kyo fan
    • Dec 2013
    • 368
    Re: 8001i J42xx
    Have you tried replacing the exit unit? Check the sensor actuators in it. Paper wears them down a lot.
    • wragsdale
      • Jul 2014
      • 188
      Re: 8001i J42xx
      The only solution I've found (other than power cycling) is to replace the Front PWB. P/N 302LF94210
      • tmaged
        • Oct 2008
        • 1888
        Re: 8001i J42xx
        Thanks Wragsdale. Reading the description of that PWB, that would make sense. I'm curious why it clears if it's not a firmware issue of some sort. I would think if the front PWB needed replacing, the jam would persist even when cycling power.
        I'm just glad someone else has seen this happen. The motor doesn't shut off even though there is a jam indicated & the side door is opened.
        Hope that helps !
        -Tony
        www.dtios.com
        • Geo
          • 662
          Re: 8001i J42xx
          [QUOTE=tmaged;597480]I've had about 5 different 8001i's (latest firmware) give me this jam code 42xx at different times. When it occurs, removing the paper will just jam again until power is cycled. Even opening the door, doesn't stop the exit motor from running continuously in reverse after the jam is indicated. I slow-mo videoed it to verify that's what was happening. Curious if anyone has seen this, or has done anything to prevent it ?
          Thanks ![/QUOTE
          Let me tell you what is NOT causing this problem...It's not firmware,HDD, main pcb, engine pcb , front pcb, exit assy or power noise.
          We ran into this same problem . First we replaced the exit assy and front pcb . After replacing the parts and before turning on we tried to update the firmware and during the update the copier crashed. To make a long story short we had to replace the other listed parts to bring it back to life. Six months later same thing with the exit assy running on. The only way to reset is a full power cycle...
          I'm wondering if this is a pure programming bug that only happens under very unusual circumstances ,for example...during the jam removal process where the copier is trying to convey all the paper after a registered jam. If I remember correctly , this was one of the new features of this copier.
          Cheers...
            • 23009
            Re: 8001i J42xx
            I know this is frowned on, but have you considered downgrading the firmware? =^..^=
            • wragsdale
              • Jul 2014
              • 188
              Re: 8001i J42xx
              I have not had a callback in any case where the front PWB was replaced. All of my 8001's are high volume (1.2mil+/yr).
              • Geo
                • 662
                Re: 8001i J42xx
                . We installed these copiers close to release dates and the firmware was the release version. Now way to go lower.... But a great idea.
                • Geo
                  • 662
                  Re: 8001i J42xx
                  We have different results. With or without a new front PCB the problem pops up. We power cycle the box and it works for months without the problem ,than the some situation. Funny thing, never had this problem with the 00 models , that's why I think it a pure programing bug.
                  Are we having fun yet?
                  • ntbann
                    • Jan 2012
                    • 628
                    Re: 8001i J42xx
                    Are your machines networked? We have a bunch of 8001i at a school district. We were thinking its a bad print job causing the exit unit to continually run in reverse.
                    • tmaged
                      • Oct 2008
                      • 1888
                      Re: 8001i J42xx
                      I'm with Geo in thinking it's a combination of events that lead to this. In the event of a jam, which is displayed on the op panel, all power to motors should be cut off. Also, opening a door should cut 24 volts everywhere. Neither of these factors is causing the motor to shut off. The fact that it's running in reverse I believe is due to it pulling any pages back from the bridge unit, so they're not torn when trying to open the bridge.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      • toddanderson
                        • Dec 2005
                        • 236
                        Re: 8001i J42xx
                        My Rep sent me this QA
                        Service Bulletin Ref. No. 2NJ-0002 (H230)
                        <Date>December 28, 2017
                        KYOCERA Document Solutions Inc.
                        A B
                        C
                        Subject: Corrective measures for jam J42xx/improving durability of the fuser discharge needle (Change fuser unit) Model: TASKalfa 8002i, TASKalfa 7002i
                        • protec
                          • Feb 2005
                          • 25
                          Re: 8001i J42xx
                          A B
                          C
                          That bulletin doesn't seem to show up on the Canadian KDA site. Can you e-mail me a copy?
                          cliff@protocol-tech.com
                          Thanks.
