KM 2552ci - C4201 error
  • copier tech
    • 8221
    • 23010
    Re: KM 2552ci - C4201 error
    Laser codes on Kyocera can be caused by poorly actuated doorswitches or resistance in the doorswitches, or primary charge shorting. Check those things first. They're much more likely and much less expensive. =^..^=
    • copier tech
      • 8221
      Thanks for your reply.
      I removed & checked the transfer unit while on site.
      Any door switches in particular? as i'm not getting any 'door open' message, machine comes to a ready state it's only when I do a copy or print the error appears.
      • craigster
        • Apr 2016
        • 201
        here is something I found on Kyocera site!!
        • copier tech
          • 8221
          Awesome, thanks
          • copier tech
            • 8221
            Originally posted by eburns
            did you find out what the issue was
            Hi,
            I replaced the laser unit this resolved the issue.
            We sent it back under warranty.
