KM 2552ci - C4201 error
Re: KM 2552ci - C4201 error
Laser codes on Kyocera can be caused by poorly actuated doorswitches or resistance in the doorswitches, or primary charge shorting. Check those things first. They're much more likely and much less expensive. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Thanks for your reply.
I removed & checked the transfer unit while on site.
Any door switches in particular? as i'm not getting any 'door open' message, machine comes to a ready state it's only when I do a copy or print the error appears.Let us eat, drink, and be merry, because tomorrow we may die!
here is something I found on Kyocera site!!Attached FilesComment
Hi,Originally posted by eburnsdid you find out what the issue was
I replaced the laser unit this resolved the issue.
We sent it back under warranty.Let us eat, drink, and be merry, because tomorrow we may die!
