TaskAlpha 2551ci & 2550ci fuser
  • copier tech
    • 8142
    Quick question, will the 2551 fuser fit a 2550 please?
  • patrickjlc
    • Feb 2015
    • 225
    Re: TaskAlpha 2551ci & 2550ci fuser
    I think so.
    Sent from my SM-G930V using Tapatalk
    • Scott
      • 196
      I don't think so
      • GeneOR95
        • Feb 2018
        • 161
        No matter what after market sellers may say, NO.
        TA-2550ci Fuser Unit , FK-8315
        TA-2551ci Fuser Unit , FK-8325
        They do have some differences and the generic units kinda sorta work in multiple models but the OEM units are not interchangeable.
        • sparkycivic
          • Apr 2017
          • 348
          That's too bad, it was nice that the 255 and 8525 could both work with the same fk-896.
            • 23006
            Originally posted by patrickjlc
            I think so.
            Clearly this is false. The KM-255C, KM-2550ci, KM-2551ci, FS-8525MFP are all Hanabi's. The KM-3051ci, KM-3551ci, KM-4551ci, and the KM-5551ci are all Alphard II's. =^..^=
            • Ropariva
              • 664
              The FK-8506 IH units are a common item across the Hanabi and Alphard range. The fuser units themselves are different. They are mostly identical from the 2550 to 2551 apart from the board/plug. Put the wrong one in and you will get an error. Likely you can swap the boards and wiring over if desperate.
