Problems with TR-8550 Transfer assy
  • taskalfa
    • Jun 2011
    • 97
    [CQ] Problems with TR-8550 Transfer assy
    Hey Techs, has anyone been getting problems with these new transfer belts tr-8550, so far we have had a few tear at below 70k and some with hardened toner at exit nozzle causing smudges. All problems have been on high speed units 4052ci and 5052ci
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Problems with TR-8550 Transfer assy
    Yes and yes. The clogged pipe will also cause a transfer motor stall code and gear ratcheting. Just warranty and move on.
      • 23007
      One of our techs worked on this issue yesterday. The call was for squeaking.
      • sparkycivic
        • Apr 2017
        • 348
        For us, actually so far so good, had a couple of early machines code with transfer cleaning motors while they were still young, then zero since. I haven't seen a torn belt ever, except for the stupid blue-dot-MK ones for the B+W older and 7002-type which don't want to stay centered.
          • 23007
          Like this Sparky?:
          Re-doing the shims seems to stabilize the centering. =^..^=
          • JR2ALTA
            • Feb 2010
            • 2033
            Like this Sparky?:
            [ATTACH=CONFIG]43093[/ATTACH]
            This thread is about the primary transfer belt. TR8550.
            • KYO_OEM
              • Aug 2011
              • 712
              Hi guys,
              i am wondering a little bit about this thread.
              In europe we are facing a lot of problems with blocked waste drive and KDC said: We are the only ones. No informations from other markets about this problem available.
              O our market this problem is coming up after FW Pack 2.05 (disuse of overflow detection by the piezoelectric sensor)
              We found that wastebox can`t forward the waste toner if weight > 600g. Fulllimit by FW controlling 800g!
              Mostly happens at high humidity enviroment and rough paper usage.
              Iris high color and mono, not so often at Iris low.
              Exchange from waste drive unit, waste box unit, Belt, feed drive gear and sometimes DV + DK for yellow needed.
              Meanwhile waste drive unit and WTB unit would modified by KDC, but problem is still remaining.(not so often, but 2-3 times per week...)
