Taskalfa 5551ci service mode entering code changed
  • Alexsiskm
    • Sep 2018
    • 11
    Dear Colleagues,
    Someones changed service mode entering code on Taskalfa 5551ci. Any Ideas how to reset it to default without entering in service mode? If you have any scripts or Vendor access code please send PM.
    BR. Alex
    Re: Taskalfa 5551ci service mode entering code changed
    Originally posted by Alexsiskm
    Dear Colleagues,
    BR. Alex
    that would be covered in the service manual
    • Ropariva
      • 671
      • Alexsiskm
        • Sep 2018
        • 11
        I'm talking about the 8 digit code for entering to maintenance menu. Service engineers code. Don't mess with admin passwords or web passwords.
        • copier tech
          • 8142
          Who could have changed this one of your fellow techs?
          • Alexsiskm
            • Sep 2018
            • 11
            Yes, thats what im talking about. Some one of our competitors changed it by u010. But I cannot enter to change it back now. This is our rent machine by the way.
            • Ropariva
              • 671
              • GeneOR95
                • Feb 2018
                • 161
                The only way to recover from this is with the factory engineering code. If you don't have that code you will need to have a Kyocera tech rep visit the machine.
                • Alexsiskm
                  • Sep 2018
                  • 11
                  I thought so. Can anyone share the code, PM?
                  • KYO_OEM
                    • Aug 2011
                    • 712
                    There is no hidden code available anymore because of foren like this.
                    Too often the hidden code like 30363036, 79x4x31x, or others would publiced by any technicians.
                    Now you need special USB key for registration procedure at the system.
                    Only Kyo tech can do this.
                    If i remember correctly, at Venus/ Gaia range this code would stored on operation panel pwb, but i am not shure by 100%.
                    You can try with other op panel pwb...
                    • JPazy
                      • Jul 2019
                      • 30
                      You may want to try running Data Sanitation under System/Network - Data Security. It takes six hours or so, it usually defaults everything but counters back to factory settings. Not sure if it'll reset a service code but may be worth a shot
                      • artago
                        • Sep 2019
                        • 1
                        Dear Colleagues,
                        BR. Alex
                        Have you tried to reset device to factory default from Command Center : management settings/reset ?
                          • 23007
                          I don't know if this PreScribe command still works on the AlphardII series, but you might try an Engine Reset:
                          Send the following PreScribe command: !R! ACNT "REST";EXIT;
