Kyocera Taskalfa Console Machines
  • mita
    • Sep 2010
    • 87
    I have found several of these machines with gaps in the rollers (assist) on the pf units causing jams. Kyocera hasn't released a fix for this other than to say stretch the spring. The roller is visible when you open the right convey side and look at the exit of the feed unit. You will see a gap between the white and grey rollers. Just a heads up if you haven't seen this already!
    • 23008
    Re: Kyocera Taskalfa Console Machines
    For the last 5 years or so I've been installing stronger springs at those idler rollers. There's been a bulletin since 2011, see attached:
    3mm paper skew mainly from tray #1, but other trays too. Inadequate spring pressure at the (4) assist pulleys. Standard spring is 5.5mm diameter coils, 9mm uncompressed length. Center assist pulley has adequate spring pressure. For two trays install (8) longer springs 5.5 to 6.0mm diameter coils, 17mm uncompressed length ([8] 302K929780 spring, [8] 2FM04150 cap).
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1887
      What are the jam codes you were experiencing ?
      Thanks for the heads up.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • mita
        • Sep 2010
        • 87
        On the log was 0519 and 0000 the customer complaint was the machine would just stall and sit in "processing" the would power it off after it started this and have the jam. It seemed more like it was a paper delay issue and changing the spring tension resolved it. The Bulletin BlackCat posted uses the new style springs which are about 5mm to short, I found some of the older style springs and if used without the plastic caps work very well for this. 302F925780.
        Thanks!
        Brian
