TaskAlfa 2551ci poor black quality
  • copier tech
    • 8174
    [CQ] TaskAlfa 2551ci poor black quality
    Hi all, please see attached sample scratching my head with this one.
    Machine has recently had Maintenance kits A & B but we still have this weird quality issue.
    When I first arrived it made a clicking sound & threw C2700 after a restart this cleared.
    Any ideas!?
  • Ropariva
    • 680
    • sparkycivic
      • Apr 2017
      • 348
      Re: TaskAlfa 2551ci poor black quality
      Did it do that with another transfer belt? That code is belt release motor error, see if the rollers inside the trans belt isn't damaged or have some junk wrapped around it... maybe the whole belt isn't seated or is twisted?
        • 23009
        Yeah, I think the belt is tracking off the side making the belt surface wavy. Something inside the primary transfer belt assy. =^..^=
        • Santander
          • May 2009
          • 768
          From the example you provided, if the transfer belt was tracking off it would affect all colors not just the black. My guess is that you have the black laser scanner not getting up to speed. Pull the laser scanner assembly and swap the black scanner with another color and see if the problem follows. If it repeats on the new color you have identified your problem.
