TaskAlfa 3051Ci faded colors to the back side
  • gratiann
    • Mar 2013
    • 5
    [CQ] TaskAlfa 3051Ci faded colors to the back side
    Hello to all,
    Have a 3051Ci with 60 K on color and 70 K on B.W
    On the Cyan, Magenta and Yellow, the print are faded on the back side of printer.
    refreshing the developing unit - no improvement
    cleaning the laser unit (system menu) - no improvement
    cheking the value of toners level in DevUnit - all ok (512 aprox)
    drum refresh (system menu) - no improvement
    replace DevUnit - no improvement
    replace Drum unit&charge roller - no improvement
    replace transfer belt unit - no improvement
    when is full color on eack color the output is ok. when is low coverage, the back side of the image is white.
    what can be? the lens and mirrors inside the Laser units? the High voltage board? (1 or 2)?
    thanks in advance
    PS: the mixed color is from scanner
    u464.jpgu089 KCMY.pdf
  • KYO_OEM
    • Aug 2011
    • 721
    Re: TaskAlfa 3051Ci faded colors to the back side
    lens, polygon motor mirror and mirrors from LSU are a very good idea!
    • gratiann
      • Mar 2013
      • 5
      But if is the laser, why is not seen this problem on solid colors?
      • KYO_OEM
        • Aug 2011
        • 721
        for solid colors, laser is working with max. power!
        • gratiann
          • Mar 2013
          • 5
          i dont know that the laser has more power levels (I thought that the cylinder load is the only variable in determining the degree of color loading)
          i will try next days to clean the LSU's and i let you know
          thanks
          • KYO_OEM
            • Aug 2011
            • 721
            you must open the LSU units!
            Mostly dust inside, coming from cooling fans
            • Tonerkiller
              • Oct 2012
              • 668
              clean the polygon mirror.
              • Ropariva
                • 683
                The mirror faces on the laser polygon mirror become dirty in certain environments and it happens unevenly and to one end due to the rotation. See pic
                • tsbservice
                  Field tech
                  • 8028
                  Yeah poly mirrors sometimes get dirty. No matter brand. Just like in your picture.
                    • 23009
                    I think I'd concentrate on the magenta and black laser slit glasses. It's not uncommon for the developer to dump more at one end, and if the toner is deep enough, the electronic cleaner just won't do the trick. =^..^=
                    • J-Tin
                      • May 2020
                      • 12
                      LSU needs good internal cleaning. If no improvement, may need to replace each of the LSU which are having this issue.
                      • gratiann
                        • Mar 2013
                        • 5
                        yes, this was the problems.
                        just like in the picture.
                        after cleaneng poligon mirrors, all is good now.
                        thanks to all for your support
                        have a nice day.
                        • NTS_cz
                          • Feb 2021
                          • 3
                          have a nice day.
                          Yes, this was problem as well, thanks' What I found wierd was, that normal prints and printing Status page had this problem, but Service status page from maintenence mode was fine.
                          And btw there is bulletin "2N4-0032 (F048)" which basically says that you should stick some tape around the plastic covers of each LSU unit.
