Kyocera taskalfa 3551ci Scanned/Copy image prints yellow background
  • veghwa
    • Apr 2019
    • 8
    [CQ] Kyocera taskalfa 3551ci Scanned/Copy image prints yellow background
    Need help
    Im experiencing this yellow background when printing for every scanned image. Its like behind text it is grainy
    Tried to Replace
    DV unit Y
    DU unit Y
    HV board
    Tried to
    Scan from different machine
    Both printed same file
    Other machine is okay
    The faulty one still prints background
    If i will calibrate
    It will solve the issue and work for a couple of days
    IMG-20200718-094000648 — ImgBB
    Any suggestions pls
  • Luther
    • May 2006
    • 682
    Re: Kyocera taskalfa 3551ci Scanned/Copy image prints yellow background
    You need to use the scanner charts and follow the instructions in the manual, they are not cheap
    • Ropariva
      • 680
      What print driver is in use? KX driver ?
      You are seeing registration creep or artefacts in the printed image. If your registration is shifting and 469 fixes it but it returns then you may have a engine board/laser issue.
      • veghwa
        • Apr 2019
        • 8
        Bro actually i tried to scan from a different machine same model
        That file i printed also
        Still it will print background behind the text
        • toddanderson
          • Dec 2005
          • 236
          Run u411 chart than run u410 after
            • 23009
            So scans are OK, but prints have registration shift?
            I suggest that you do a color calibration. In the packages that contained the drum and the developing unit there was a piece of A4 paper telling you how to do it. Did you look at that piece of paper? =^..^=
            • veghwa
              • Apr 2019
              • 8
              The scanned file quality when checking in computer (zoomed in) will have some grainy shade back ground
              IMG-20200716-120455074 — ImgBB
              It will attract yellow color in that particular grainy part behind the text.
              The weird part this same file i printed on another machine (same model) it came out normal.
              Recently i replaced itb unit for testing but still no luck
              Tried to factory reset also
              Still same issue.
              Registration actually is okay.
              Print report from machine and files coming from word or any apps are okay.
              • Crusher
                • Jan 2018
                • 17
                Firmware is listed. Then do order developer refresh, calibration and then toner curve. Out of service manual. Hope it helps. You may have to do developer refresh process a few times, not sure why it gets stubborn.
                • Lunatech
                  • Oct 2012
                  • 210
                  Is it being printed as full color, auto color or black and white. Might try auto color or black and white. Heck see it there is a difference for all of them just for the fun of it.
