Magenta background
  • muhammadreza
    Lerner
    • Aug 2012
    • 39
    Magenta background
    I change magenta drum developer and charger. When make few copy print are ok but when make many copy it will come like this ! Why it happen ? Machine model TASKalfa 5551ci
    • 23008
    Re: Magenta background
    You left out two crucial pieces of information:
    What size is the image in the photo?
    What direction is the feed direction? (Are those bars crossfeed?)
    If I knew the answers to the first two questions I would already know the answer to the third question: What interval in millimeters between the bars?
    I'm going to make a guess that the interval is 21mm on an A4 image LEF, bars crossfeed. True?
    • muhammadreza
      Lerner
      • Aug 2012
      • 39
      A4 pdf file and direction off paper are A4
      And thanks to replay I already solved the issue
      • copier tech
        • 8144
        Looks like those marks are caused for the transfer belt.
        • davel
          • Oct 2011
          • 1104
          So what was the fix?
            mind sharing with the class what the fix was?
            • M94
              • Jul 2020
              • 158
              Hey I'm essentially brand new to these forums and really just surfing around trying to learn from other peoples issues\solutions. Would really appreciate it if you could post the solution otherwise this post doesn't really help anyone having the issue in the future.
              • muhammadreza
                Lerner
                • Aug 2012
                • 39
                U100 (adjust main high voltage output) Adj Ac bise (Ac bise [M])
                and set AC Auto Adj off
                • KYO_OEM
                  • Aug 2011
                  • 715
                  Set AC Auto Adj. set to "off" ?
                  Bad idea, you`ll get other density problem in near future.
                  Not only [M], also [C,Y,K] possible.
                  Now system won`t calculate needed correct voltages anymore.
                  You will have no fun with this setting.
                  • bush_tech
                    • Jul 2018
                    • 51
                    this is the fault you can sometimes get when a drum is replaced without turning off the machine, the serial number and counter won't get cleared and there will be background unless ac auto adj is off
                    • copier tech
                      • 8144
                      You have to turn the machine of to replace the drum or it will error & even blow a board!
                      • KYO_OEM
                        • Aug 2011
                        • 715
                        We are talking about "old" Venus range.
                        At this range we can get this problem if needed adjustments wouldn`t done.
                        E.g. no U119, no U410, etc....
                        You has to shut down the system and unplug from power plug everytime before start from disassembling at each system.
                        • bush_tech
                          • Jul 2018
                          • 51
