need help,how to solve white line on paper kycera km2050.
  • Drivee
    • Nov 2020
    • 322
    Re: need help,how to solve white line on paper kycera km2050.
    [QUOTE=blackcat4866;1624033]I'm going to guess that there's an obstruction under the doctor blade, in the developing unit. Such obstructions can shift around. Or you might have a buildup of toner on the developing roller.
    For the obstructions you can make a mylar "hook" to fish them out. Lets see if I have a photo:
    Well someday I'll learn how to drag & drop on the phone. =^..^=
    Mylar Doctor Blade Cleaner.JPG[/QUOTE
    He say that he try to replace Dev unit so it is not a Doctor blade.
    • KYO_OEM
      • Aug 2011
      • 709
      did you tried to print a page without installed main charger?
      Full solid image without white lines, it`s coming from laser or mirrors
      Full solid image with white lines, it`s coming from DV unit
        I gotta try this. Great information as always.
        • ThememoriesIII
          • Nov 2020
          • 9
          #19
          Sorry for late i drive car all day and did not do anything to repair a machine but I order ipa 99.99% on internet market Thailand and before go to home i try to print reports white line is on paper to.
          • ThememoriesIII
            • Nov 2020
            • 9
            #20
            Thank you all so much for help me and guide. to day i solve a problem with a small paper i take out a develop unit to check a blade but i see a pcb lasor is bend and a lasor head not linear i try to put a small paper under pcb and put develop unit to machine and it work white line on paper is remove.
              • 22999
              #21
              I'm pretty sure I know the answer but I gotta ask before I make one of these. I like it. Have you ever damaged a doctor blade with the mylar hook?
              I tried it on a KM-7002i. I got a fuzzy-ball of what could be carpet lint, but did scratch up the white coated developing roller. Only on Kyocera is that coating so sensitive. A month later I ended up changing that developing unit for a different problem (overtoning). The scratches did not seem to affect the image quality.
              • Scott
                • 194
                #22
                DV unit
