3551ci background problem
    • 16394
    Re: 3551ci background problem
    Originally posted by KYO_OEM
    FIG. 23 Electrical Components 1
    Item #7, below the belt.
    If you remove the belt, you will see both sensors.
    Covered by shutter
    But i don`t think it`s the reason in your case.
    If we get problems with this sensors, last calibrations would show "0" instead of "1".
    MAybe you don`t know how to read binary coding.
    You has to read from the right side.
    16th -12th calibrations last 4 calibrations
    0111 1111 1111 1111
    I think I found it. You're talking about the spring loaded shutter with the 2 slits?
    • KYO_OEM
      • Aug 2011
      • 718
      YES!
        • 16394
        YES!
        PS - I understand how to read binary but I'm not grasping what you're saying. Maybe when you have time you can help me understand better. I appreciate all of your help.
          • 16394
          #19
          Nevermind, I understand now. Thanks.
          • KYO_OEM
            • Aug 2011
            • 718
            #20
            e.g.
            1111 1111 1111 0000
            last 4 calibrations failed
            0000 1111 1111 1111
            calibration 12 -16 failed
            If the ID sensors don`t work, you must get
            0000 0000 0000 0000 instead of 0011 1111 1111 1111
            and U468 shows "0" instead of "16383"
            Maybe we have problem with Dv stations because of DV powder stress inside.
            We are talking about 35ppm system.
            Needed time for each page = 60 seconds/ 35ppm
            ~1,7 seconds/ page during multiple printing
            Now you can check needed time at your system:
            U157 * 60/ U158 will show you the needed time/ page at your system.
            We have had systems with values > 6 seconds and we got faint images or background.
            After running developer refresh, system works well for a few days, but problem came back.
            Let me know U000/Maintenance Report
              • 16394
              #21
              e.g.
              1111 1111 1111 0000
              0000 1111 1111 1111
              I'm going back to the account today. I will get you U000/Maintenance Report. Thanks again.
                • 16394
                #22
                I went back today and the machine finally printed with a blue background while I was there. This turned out to be the call from hell because it's in a medical office that's very busy and they rely on this one copier to do everything and they kept asking me if they could make a copy/scan/fax every 5 minutes. Then I got in a hurry and the fuser slipped out of my hand and it broke the exit gate off. I had to go back to the shop and grab another one. Whew!!!
                After all of that I replaced the cyan DV, DR and PCR. It worked fine after that but we'll have to see as this has been a very intermittent problem.
                Edit: I'm never gonna rush a job again. They'll just have to get pissed off or whatever. No more rushing. This is one of my bigger accounts as they have about 10 different locations on the Gulf Coast.
                  • 16394
                  #23
                  KYO,
                  The information you shared with me is very informative. Eye opening, really. But I don't see that detailed of information in the Service Manual. How did you discover this? Just curious.
                    • 23008
                    #24
                    I went to AlphardI class training in Dallas, and I'm pretty sure this never came up.
                    I would have remembered. =^..^=
                      • 16394
                      #25
                      I plan on doing some tests and I'm gonna make the machine purposefully fail calibration and check it against the information that KYO provided. It is interesting because you can basically eliminate certain parts/supplies as being the problem by reading the numbers that KYO posted.
                      • bronco31
                        • Aug 2009
                        • 174
                        #26
                        All I see is... (The Matrix) - YouTube
                          • 16394
                          #27
                          Originally posted by bronco31
                          That's what it looked like to me at first. But it's really not that complicated. And I can tell you this with certainty - everything KYO said is true.
                          Even after understanding how to read/acquire the data, it took a minute for me to get the big picture.
                          At the heart and soul of the color copier is the calibration process. Who wouldn't want to know if the last 16 calibrations failed or passed? That's only the starting point of the big picture. The next step is to look at other data such as Service Call Log on the Event Log. That can help further isolate as to why calibration failed.
                          Of course, a very experienced tech has probably seen just about everything and they'd have the problem fixed before I could convert V-correction to binary. Still, it's another tool in the tool bag.
                            • 16394
                            #28
                            By the way, I officially switched over from using the internal test charts in the machine to the ones that blackcat uses. They simply show more imperfections.
                            • bronco31
                              • Aug 2009
                              • 174
                              #29
                              just print from a usb drive?
                              Yes calibration huge mystery to many of us !
                              Also on my mind a question:
                              Heres the latest Kyocera out in Europe: TASKalfa 3554ci
                              If this is the FOURTH generation of this model design.. shouldn't it be utterly bulletproof and every flaw and design hardware/software error corrected thus a now super reliable copier?
                                • 16394
                                #30
                                Yes, from a USB drive.
                                I've yet to see a bulletproof copier.
