Some one posted a document on that mode. Energy saver default is like 1 minute to sleep which stops the fuser from rotating. Of course 99% of people would never accept that so the machine gets it's timers cranked to max (bad bad bad). The fuser will sit and rotate for hours. U346 with fuser power mode off if i recall lets the fuser rotate for 1 minute while the machine is idle before it turns off the motor. This will cause the fuser to make the majority of it's life before the bearings blow up.
Silent mode is a better option. As soon as the job is done the fuser stops turning which results in the fuser making life. This works well on the TaskAlfa A3 devices. DO NOT do this to A4 or Ecosys A3 devices. The machines will run at half speed and don't have the rotation issue so there is no reason to turn it on.
