Customer called and said the copier says load paper in tray 4 when printing to it (Pic attached). I assume that the paper tray settings in the driver are not set right but the customer says they are. I am heading there in the morning and any help would be very helpful. Thanks !!!IMG_0522.JPG
Taskalpha 4551ci When printing to copier says "Load tray 4"
Re: Taskalpha 4551ci When printing to copier says "Load tray 4"
It's telling you to load Custom3 media type, not plain. It's probably using the windows driver, not the KX. -
I'm still having issues with this monster (Wish I was a better IT guy) Just to give you the background; When you would send a print to the copier letter size, the copier would say to load tray 4 with letter custom 3 type paper. (Pic attached). Assuming that a windows driver was initially installed, I changed the machine tray settings to custom 3 on all paper trays. When that did not work I installed the KX driver off the Kyocera website. After installing the KX Driver the copier would say to load letter size paper in tray 1 no matter what type of paper you sent to the machine.
All the work station have this problem in there office but only 1 (That I was working with) have the KX driver that I just installed.
Thanks for any help. Even Kyocera Support is scratching there head on this one...
ask Kyocera for a remote session
Document settings will override print driverComment
Does tray #1 show "STMT-R" paper size? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
No, It shows ledger. Tray 1 and 2 are loaded with ledger and 3 and 4 letter paper.Attached FilesComment
Is there a C26xx error message stored?
If tray #3 or tray #4 is overloaded, the paper pickup motor will stall, and isolate trays #3 and #4. My suggestion is to make sure that all jams are cleared and paper not overloaded. Perform partial reset U906.
I will give this a shot Monday morning. Also going to remove the old windows drivers. Hopefully that will finally fix it. I will post my results on Monday... Thanks so much for all your help !!!Comment
Is the issue only with tray 4?
Update the firmware after deleting the skip file, possibly it has been corrupted.
After I loaded the KX driver, The copier started asking to load the correct paper 8 1/2 x 11 in tray 1 (Which is loaded with Ledger). I looked through the firmware files and couldn't find a skip file. Thinking it was used on Turbo firmware which I don't use... Thanks so much for your help !!!Comment
Skip.jpgLet us eat, drink, and be merry, because tomorrow we may die!
I finally fixed this thing... I re-loaded the firmware (No Skip File). I set copier back to factory defaults (After U917) Reset tray 3 and 4 connectors then U906. I set the default tray to 81/2 x 11 to tray 3. (Ledger is loaded in one and 2) I also had to set the printer settings to auto tray select which was set to off. Thanks for all ya'lls help !!! I couldn't have fixed it without you guys !!!Comment
