Taskalpha 4551ci When printing to copier says "Load tray 4"
  • Doug James
    • Jan 2012
    • 935
    [Misc] Taskalpha 4551ci When printing to copier says "Load tray 4"
    Customer called and said the copier says load paper in tray 4 when printing to it (Pic attached). I assume that the paper tray settings in the driver are not set right but the customer says they are. I am heading there in the morning and any help would be very helpful. Thanks !!!IMG_0522.JPG
  • tmaged
    Owner/Service Manager
    • 1889
    Re: Taskalpha 4551ci When printing to copier says "Load tray 4"
    It's telling you to load Custom3 media type, not plain. It's probably using the windows driver, not the KX.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Doug James
      • Jan 2012
      • 935
      Very Helpful THANKS !!!
      • Doug James
        • Jan 2012
        • 935
        I'm still having issues with this monster (Wish I was a better IT guy) Just to give you the background; When you would send a print to the copier letter size, the copier would say to load tray 4 with letter custom 3 type paper. (Pic attached). Assuming that a windows driver was initially installed, I changed the machine tray settings to custom 3 on all paper trays. When that did not work I installed the KX driver off the Kyocera website. After installing the KX Driver the copier would say to load letter size paper in tray 1 no matter what type of paper you sent to the machine.
        All the work station have this problem in there office but only 1 (That I was working with) have the KX driver that I just installed.
        Thanks for any help. Even Kyocera Support is scratching there head on this one...
          • 30310
          What document is printing PDF word etc....
          ask Kyocera for a remote session
          Document settings will override print driver
            • 23009
            Does tray #1 show "STMT-R" paper size? =^..^=
            • Doug James
              • Jan 2012
              • 935
              No, It shows ledger. Tray 1 and 2 are loaded with ledger and 3 and 4 letter paper.
                • 23009
                Is there a C26xx error message stored?
                If tray #3 or tray #4 is overloaded, the paper pickup motor will stall, and isolate trays #3 and #4. My suggestion is to make sure that all jams are cleared and paper not overloaded. Perform partial reset U906.
                • Doug James
                  • Jan 2012
                  • 935
                  I will give this a shot Monday morning. Also going to remove the old windows drivers. Hopefully that will finally fix it. I will post my results on Monday... Thanks so much for all your help !!!
                    • 8176
                    Is the issue only with tray 4?
                    Update the firmware after deleting the skip file, possibly it has been corrupted.
                    • Doug James
                      • Jan 2012
                      • 935
                      Update the firmware after deleting the skip file, possibly it has been corrupted. After I loaded the KX printer Driver
                      After I loaded the KX driver, The copier started asking to load the correct paper 8 1/2 x 11 in tray 1 (Which is loaded with Ledger). I looked through the firmware files and couldn't find a skip file. Thinking it was used on Turbo firmware which I don't use... Thanks so much for your help !!!
                        • 8176
                        • Doug James
                          • Jan 2012
                          • 935
                          I finally fixed this thing... I re-loaded the firmware (No Skip File). I set copier back to factory defaults (After U917) Reset tray 3 and 4 connectors then U906. I set the default tray to 81/2 x 11 to tray 3. (Ledger is loaded in one and 2) I also had to set the printer settings to auto tray select which was set to off. Thanks for all ya'lls help !!! I couldn't have fixed it without you guys !!!
