3551ci, color difference
  • Ropariva
    • Mar 2016
    • 639
      Re: 3551ci, color difference
      Originally posted by Ropariva
      Have you checked the colour tables? U485. The darker one looks like it’s using FJ
      I owe you one. That was exactly the problem. I changed it to KY and it's back to normal. Thank you.
      • Ropariva
        • Mar 2016
        • 639
        No problem. If we have a client with problems with blues we will generally use the KO (Konica) table.
        Just RE run the tone curve after the reboot.
        • tsbservice
          Field tech
          • 7944
          #19
          For that purpose we have tool comparing default soft switch values to the machine or between two machines. Comes handy at a times. Just out of curiosity, what FJ brand profile is. Maybe Fuji Xerox?
          • Ropariva
            • Mar 2016
            • 639
            #20
            • Samanator
              • Sep 2017
              • 571
              #21
              I think the color tables go like this:
              CA = Cannon
              FJ = Fuji
              HE = HP
              KO = Konica
              KY = Kyocera
              RH = Ricoh
              ST = Sharp
              TO = Toshiba
              The two and three series seem to already have the color tables installed outta the box. There are a couple of new settings (K1 and A1), but I have no idea what those are as of yet.
              I mostly set my machines to RH for reasons I have explained in another post. Basically, the default KO will get you the best yield out of the toner. But to me, the color is lacking. RH uses a bit more black toner but looks way better. I take the trade-off of using a bit more black because the black toner cartridges are bigger anyway. The TO may look good but that setting just slops gobs of toner on the page. I only use that one when I have to...... just sayin'.
              • Ropariva
                • Mar 2016
                • 639
                #22
                • KYO_OEM
                  • Aug 2011
                  • 704
                  #23
                  i searched for more informations and found the following:
                  K1 would implemented by FW in past.
                  • KYO_OEM
                    • Aug 2011
                    • 704
                    #24
                    additional older informations
                    • fishleg
                      • Mar 2009
                      • 426
                      #25
                      I have 2 3551ci's in the shop. Both using OEM toner. One has 100k on it. The other has 50k. When I print out the test charts there's a difference in color. See test charts below. Notice the difference in the last row of color. One is magenta and the other looks purple. There's also a more slight difference in the blue.
                      Maybe someone with more experience than me can give me a clue. Thanks. See below:
                      [ATTACH]48308[/ATTACH]
                      Could I have that test chart please if it's a pdf ?
                        Here you go.
                        11% ANSI A Color 8.5 x 11.pdf
