M 2040dn making strange noise
  • chester
    • Jun 2016
    • 37
    Have got a colleague who is getting an intermittent noise from one of these M2040 desktop printers.
    He advises me that it appears to come from the rear of the device and once the fuser is changed goes away.
    Problem being he has now gone through two fusers and one fuser drive in the space of a month for this issue and it has returned again.
    He confirmed that the drum unit was replaced on the first visit for pcq.
    I have heard of another one of these models doing the same thing, but never heard back what the fix was.
    Has any body had this or any ideas please?
  • KYO_OEM
    • Aug 2011
    • 721
    Re: M 2040dn making strange noise
    Firmware upgrade to V2.02 would done?
    short extract from bulletin:
    • lees
      • Apr 2011
      • 95
      All the noise problems we have seen with these machines has been the fuser or the fuser drive.
      • KYO_OEM
        • Aug 2011
        • 721
        new Fk and/ or fuser drive solved the problem for a while.
        Without new implemented cooling cycle by FW upgrade it will happen again.
        • chester
          • Jun 2016
          • 37
          Hello KYO OEM and lees
          On behalf of my colleague, thank you for your quick responses and I will pass the information on.
          Once again, thank you.
          • Samanator
            • Sep 2017
            • 579
            When I have a customer that has a noise problem, I give them a radio and put it on the station they like and turn it up till they can't hear the noise.
            If that's not enough, I get two radios.
            • kuby
              • Oct 2007
              • 1409
              Try stretching the spring in the fuser drive unit. Or replace the fuser.
              • theh5n1
                • Oct 2023
                • 1
                Stretching the spring in the fuser drive unit worked for me. At least for now.
                • Ropariva
                  • 679
                  [ATTACH=CONFIG]48394[/ATTACH]
                  We have a few years of info on these fusers with 100 plus machines in our region. Even after applying the firmware we have seen no increase in the life expectancy of the fusers which are typically failing at 30-35k prints. Have there been any real improvements made at the factory to these? It just seems that they are a flawed design.
                  Sent from my iPad using Tapatalk
