TASKalfa 2551 ci blue lines on the top of the sheet
  • ernesto
    • Oct 2011
    • 430
    Hi
    A Taskalfa 2551i ci prints blu lines on the top fo the sheet in color mode
    I always repair canon machines( the customer ask for a favor) and this problems it seems cyan drum problem, how can I know the drum life in this machine
    I hope an answer from you soon
    All the best
    • 23008
    Re: TASKalfa 2551 ci blue lines on the top of the sheet
    10871087 > browse to U251 to see yield on maintenance kits. Cyan drum is part of Maintenance Kit B.
      • 8156
      Originally posted by ernesto
      Hi
      All the best
      You can swap the drums round to help trouble shoot, so swap with the yellow for example.
      They also respond well to cleaning if its dried on toner clean it off with alcohol etc.
      • ernesto
        • Oct 2011
        • 430
        HI blackcat thank you very much for your answer
        I enter in service mode and M Cnt A is 109.812
        M Cnt B IS 30.527
        do you know what is the black drum life and color drum life?'
        I swap yellow drum and cyan drum(how copy tech said )and the prints are improving but still there is a llitle blue on the top of the sheet, .......I thought that doing that the lines on the top of the sheet would be yellow..... do you know what is the reason??
          • 8156
          M Cnt B IS 30.527
          Ok, so you can rule out the drum being the issue.
          Take out the cyan dev unit can you see a build up on the roller?
            • 16395
            Post some examples, please. Thank you.
            • ernesto
              • Oct 2011
              • 430
              the blue lines are on the top of the picture
                • 8156
                Have you checked the cyan dv unit?
                Firmware is out dated, 2014.
                  • 16395
                  Hard to tell from that example. Print out test charts @ U089 and post those please.
                    • 23008
                    That does not look like lines to me. It looks like overtoned cyan developer. =^..^=
