TA-3551
    • 16416
    TA-3551
    I have a customer that does a high volume of scanning and about every 2 weeks I get a call for black lines. It's always due to something on the slit glass. It's very hard to see with the naked eye unless you shine a light on it. Whatever's on the slit glass won't clean off with a rag and alcohol. It's a very hard substance and I have to scrape it off with a flat blade.
    Anyone ever run across anything similar? I'm thinking they're scanning paper with some type of adhesive??
    • 23009
    Re: TA-3551
    Here's something you can try:
    Get yourself some self-adhesive mylar, and cut out some rectangles 5mm x 22mm (4 should be enough).
    Identify the area of the white plate that contacts the ends of the slit glass. Install one of your mylars at each end of the slit glass to increase the gap to the white plate by ~0.33mm. Make sure that these mylars are not in the original path or they'll cause jamming.
    On a few occasions, I've gone back and added a second layer, but usually 1 layer is enough.
    Now if that contaminent is wet when passing through, this won't make any difference.
    • dalewb74
      • Feb 2018
      • 1157
      Re: TA-3551
      i don't believe i would use a flat blade on the glass. i typically use my thumbnail whenever cleaning solution doesn't remove something on the glass. that prevents a possible scratch. personally i haven't seen something that difficult to get off the glass occur that often. i did have a customer tell me once she had to clean the adf glass daily. and after cleaning copies come out clear. i happened to look up and noticed the AC vent was overhead and about 15 ft from the copier. and that vent was covered with dust. plus they have someone come in every few days and clean the office. i would just be mindful of the entire environment around the copier. though i bet you have thought of that already.
        Re: TA-3551
        awesome MacGyver !
          • 16416
          Re: TA-3551
          I like that. Will try it next time I'm out that way. Thank you.
          • dalewb74
            • Feb 2018
            • 1157
            Re: TA-3551
            i have been told before by one of our more experienced techs that he has used an oil on the adf glass. i have never tried this before. but he said a light coating helps prevent stuff from adhering to the glass. sorry i don't know the specific name of the oil.
              • 23009
              Re: TA-3551
              Probably silicone fuser oil, but that can accumulate dirt also, still requiring cleaning. =^..^=
              • Santander
                • May 2009
                • 768
                Re: TA-3551
                It could also be a gel pen. Have seen this before. The ink in gel pens does not dry as quickly as a ball point, so if they sign a page or make a note and then scan, the ink can come off the paper and adhere to the glass. Discovered this the hard way after getting four calls in a month on the same machine and the "substance" was always in the same area on the slit glass. Questioning the customer discovered that the area where the "dirt" was where they had clients signing on a form. Looking at the pens available for the clients, they were all gel pens. Had the customer sign a form with my ball point pen and then scan no problem. Had the customer sign the form with their gel pen and the next scan had lines. Once the gel ink dries on the slit glass it is very tough to remove and is very difficult for a user to see [no flashlight]. You can scrape it off with your fingernail or as we do, put a few drops of 90%+ alcohol on the affected area and wait ten seconds or more and clean it off. We use alcohol because Windex does not dissolve the gel ink.
                  • 16416
                  Re: TA-3551
                  Good investigative work. I'll put that on my list of things to check.
                  • tmaged
                    Owner/Service Manager
                    • Oct 2008
                    • 1888
                    Re: TA-3551
                    Yep, either silicone fuser oil or Rain-X will help in keeping the glass clean.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                      • 30294
                      Re: TA-3551
                      You should be able to get the key operator to clean the slit glass when this happens.
                      Wow this is basic copier 101 stuff.
                      You can also use Brillianize
                        Re: TA-3551
                        most key ops now a days refuse to try due to service contracts. I help them .. talk to the boss.. he calls them and tells them we will charge for a cleaning (1/2 off) and they say never mind we can handle it OR just cuss and hang up.
                        I clean the glass both sides and apply RainX .. mirrors get RainX Anti-fog
                          • 900
                          Re: TA-3551
                          I remember some of the older feeders that the rollers would start to deteriorate getting some of the material to stick on the glass . Have not seen it yet with these feeders but its worth a check of ALL the rollers.
                            • 23009
                            Re: TA-3551
                            The Canon NP-3525 document feeder RADF1 did this. The neoprene registration rollers would gradually turn into something resembling well chewed chewing gum, peeled off the shaft and adhered to whatever was available. The general consensus among techs was that exposure to stronger solvents like trichorethylene caused this. Mostly I think it was just what happens to neoprene after 15 years.
                            • Froota
                              Field service tech.
                              • 129
                              Re: TA-3551
                              Could it be maybe a misaligned document feeder, causing the paper to scratch the slit glass?
                              It the edge of the paper is constantly bumping into the glass, you also can have problems with lines......
