Where do you find older firmware on the new website?
  • Necrocannibal
    • May 2008
    • 212
    I've looked everywhere and can't locate firmware for older machines anywhere on this redesigned site. I contacted Kyocera but not expecting any response from them. I was specifically looking for 2552ci but noticed they only have newer models to choose from in the drop down menu.
    Sent from my SM-N986U using Tapatalk
  • kuby
    • Oct 2007
    • 1405
    Re: Where do you find older firmware on the new website?
    Log in and go to Support and Select Download Center and search for that model. I found it.
    • progoffice
      • Nov 2008
      • 334
      I was just thinking the same thing. The new website is garbage, or at least not ready for prime time. They sent an email listing a readme file about a reset firmware for the 306ci/356ci. I was interested in learning more but now these links go nowhere. What used to be copystarcentral.com is now mycopystar.copystar.com. It looks more like a public site rather than a dealer site.
      • copier tech
        • 8144
        Happy to help with any specific firmware version should you need it.
        Printer & Copier Firmware - www.printerfirmware.co.uk
        • tsbservice
          Field tech
          • 8016
          You're getting quite rousing this time, aren't you
          • Necrocannibal
            • May 2008
            • 212
            I appreciate it but we got the problem taken care of. Kyocera actually contacted me back and said the website is under construction and they haven't uploaded everything to it yet but will be completed soon.
            • ntbann
              • Jan 2012
              • 628
              I just looked and TA2552ci is on the new site.
              • Necrocannibal
                • May 2008
                • 212
                They must-have put it up in the last day or two, it wasn't there when I looked.
                • Samanator
                  • Sep 2017
                  • 579
                  I agree that the new site is garbage. There are also notable differences between the Copystar site and the Kyocera site. Many things are still not on the Copystar site. And I work for a Copystar dealer.
                  I was told that if I go to kyoceradocumentsolutions.us, I could log on with my Copystar credentials. It works and I can find things that are not yet on the Copystar site.
                  Maybe that will help.
                    • 23008
                    Unlike other manufacturers, Kyocera takes down any out of date firmware versions. That's why I still have dozens of versions out of date firmware. Once the new firmware comes out, the old disappears forever. =^..^=
                    • Scottb
                      • Apr 2013
                      • 306
                      except for that one time with the 00 series and they had to take a step back...which is why I save the old firmware as well
                        • 23008
                        My first experience with widespread firmware bugs was on the FalconIII:
                        Cannot receive faxes, intermittently. "U01110" Rx errors viewable on U670 Error Log. Possible defect in firmware affecting versions 2.41, 2.43, & 2.44. Downgrading of firmware to version 2.40, or upgrade to version 2.45a or above.
                        • Stomp'Em
                          • Jun 2019
                          • 8
                          I was going to say contact Kyocera and they will either send you a link to the page, or an email with the FW. We called to called them a couple of times in the first weeks of the new site launch, and that is what they did for us.
                          • copier tech
                            • 8144
