5002i - C6600
  • ABS tect
    • Sep 2013
    • 511
    5002i - C6600
    Hey all, I'm a bit out of my element here as I typically work exclusively on Ricoh machines, but I am trying to get a Kyrocera TASKalfa 5002i up and running.
    It has a C6600 code, which appears to be a fuser belt rotation error, I have replaced the fuser unit thinking that was the cause but no luck.
    I don't have any service manuals besides what's provided online and I have no firmware for this machine as well.
    I was leaning towards thinking it was the fuser drive gear assembly but don't even know where to order that part or if that's the cause.
    Any suggestions or previous experience with this code/machine? I believe this thing is getting pretty old.
  • Ropariva
    • 672
      • 23007
      Re: 5002i - C6600
      I'm betting that you did not do the U906 Partial Reset and U163 fuser reset after replacing the fuser. Was it a new fuser unit?
      • JR2ALTA
        • Feb 2010
        • 2033
        Re: 5002i - C6600
        I think Kyocera moved past 163 a while ago.
        • ABS tect
          • Sep 2013
          • 511
          • KYO_OEM
            • Aug 2011
            • 714
            Re: 5002i - C6600
            302ND94A30/ PARTS FUSER DRIVE H ASSY SP/ 40ppm(m)/50ppm(m)/60ppm(m)
            • Tonerkiller
              • Oct 2012
              • 668
              Re: 5002i - C6600
              Make sure that, When you close the door the coupler engages the fuser.
              • kuby
                • Oct 2007
                • 1403
                Re: 5002i - C6600
                Machine first came out in 9/2016. Not that old.
