TASKalfa 5054ci with DF-7100 stapling wrong ??
  • kuby
    • Oct 2007
    • 1409
    Have a customer that is having a issue when stapling from their computers. When selecting it to staple the top left it staples at the bottom? Top right then it staples at the bottom as well. You can staple it from the copier and it staples correctly. Yes they are using the KX driver, even deleted it and reloaded it and that did not help. Firmware is up to date but going to do a FULL firmware install tonight and see what happens. Anyone ever have this issue?
  • KYO_OEM
    • Aug 2011
    • 721
    regarding orientation does they use rotated portrait or portrait only
    what happen if you print from your own laptop
    • kuby
      • Oct 2007
      • 1409
      It was set right, just stapled wrong.
      • eddie110171
        • May 2012
        • 133
        Is the problem only from one computer or multiple computers?
        • kuby
          • Oct 2007
          • 1409
          Computers - multiple.
          Installed firmware version v.3.13 FULL. Installed v.8.4.1716 driver. No change.
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1888
            I just tried it on a 3554ci with a DF-7100 that I'm setting up and it selected the correct postitions.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • kuby
              • Oct 2007
              • 1409
              Yes it works OK this way, but it was working the original way and then it stopped?
              • kuby
                • Oct 2007
                • 1409
                Our windows did updates over the weekend on our computers at the office and when my boss did printing and stapling our 3252ci with a DF-7100 is doing the same thing. So it must be a windows update that is causing the problem.
                ****** I Need to verify this to be sure ******************************
                ****** to make sure that this is really happening ********************
                • ihatefinishers13
                  Senior MFP Technician
                  • Feb 2020
                  • 710
                  Windows Updates causing a Kyocera issue? Nooooo, that doesn't sound anything like March of 2021....
