Re: Add more edge erase on printing? 8353ci
I found it handy to get a PDF onto my USB key that was having the wrap issue. I now use this as my test chart for lead edge start position. Pretty much every machine out of the box does not have this set so that lead and trailing edge void is the same. Often the settings for all paper sources are zero or under. These I now routinely set (all sources) from +1 to +1.5
