Taskalfa 3553ci Loud Popping Noise Waste toner Backed up
  • Hoosierdaddy
    • Oct 2016
    • 181
    Customer was using generic toner and the waste toner backed up and making noise. is this a common issue? Can someone get me the Service manual or insight on this?
    Not a dealer for this machine. thx for the help in advance
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    More than likely you'll need the waste toner bottle unit, the waste toner sending unit & the feed drive unit. It's a good couple of hours if you've never done it before. Then tell them to get a full set of OEM toner and replace them all. It happens a lot less frequently with OEM toner, but it does.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Lunatech
      • Oct 2012
      • 208
      I have also seen the drum cleaning assembly seized along with the above mentioned items.
      • Hoosierdaddy
        • Oct 2016
        • 181
        Thank You for the input. We have the units mentioned above out of the machine
        • Samanator
          • Sep 2017
          • 579
          Its not too hard to remove the waste toner bottle. Its mostly all about removing Drive Section 1.
          Message me your email address and I'll send you the manuals.
          • masterchill
            • Jul 2005
            • 100
            Check the transfer belt as well for lock up.
            • Larhal
              • 576
              The white gear drive breaks on the transfer belt cleaner. It will just rotate on the shaft and not spin the auger. In A pinch super glue works.
              Larhal
              If all else fails read the Service Manual!
              If that fails, meet me at the pub and we will discuss it.
              • WilliamD
                • Dec 2022
                • 2
                Our shop has seen a fair share of these on low volume machines and we have started turning on the drum heater and have yet to replace one for the last year after changing that setting.
