Scan error type: other
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Hello Gents.
    I think I saw another thread here somewhere... Couldn't find it again.
    Its scan to email, most of the time works, intermittently doesn't.
    Print out says "other", not server/setting/connect..
    Ta4500i, latest firmware, timeout 60seconds,officr365 with 587 and starttls
    Could this be a latency issue? First time I have seen this.
    Idling colour developers are not healthy developers.
    • 23006
    Re: Scan error type: other
    It would help to have the code, but that could be tricky if it's intermittent. You'll have to catch it in the act. =^..^=
    • PrintWhisperer
      • Feb 2018
      • 471
      Yes, get us the code. If it's 3102 then we should talk.
      Also note if the error occurs during heavy usage scanning with several single or small scanning jobs back-to-back.
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1880
        I would ping the mail server, then enter that IP address in the SMTP hostname field, to eliminate DNS as the possible issue. It's really the only item that could cause intermittent scan errors. And as the others mentioned, the error code is imperative to troubleshoot with. On the new machines, they finally got smart and have it print on the error pages. Previous models, you had to see it happen.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • copiertec
          • Jan 2016
          • 2205
          Is the TA-4500i TLS 1.2 or higher compliant?
          • PrintWhisperer
            • Feb 2018
            • 471
            Higher, no. TLS 1.3 will only be seen in the '4' series and beyond.
            TLS 1.2 is supported, but there have been updates to elements (i.e. ciphers) within the TLS 1.2 spec and many new RFC's which the older framework may not comply with.
            • JR2ALTA
              • Feb 2010
              • 2033
              +1. When in doubt always use IP instead of hostname.
              • diedux
                • Jan 2017
                • 124
                Hi,
                Nothing to do with a device itself. Almost...
                Lots of complaints over the last two weeks from customers who use O365. The most common complaint is: "every sixth or seventh scan job fails, wtf?".
                My best guess is that MS continues to roll out changes that were delayed (and rollbacked in some places) due to Corona stuff. It should have been enforced a year ago (2020 Oct 15).
                MS about this: Preparing for TLS 1.2 in Office 365 and Office 365 GCC - Microsoft 365 Compliance | Microsoft Docs
                Make sure device supports strong ciphers: Preparing for TLS 1.2 in Office 365 and Office 365 GCC - Microsoft 365 Compliance | Microsoft Docs
                A word about TLS 1.2 on the device. If your device does supports TLS 1.2, this does not necessarily mean it uses it for communication by default. You can try to disable older TLS 1.0, 1.1 and leave only TLS 1.2.
                • calebgk
                  • Jan 2019
                  • 21
                  Been dealing with this problem past week. All of our 00-series TA's that were previously using O365 are now incapable. I posted in the Connectivity thread about this. It seems MS deprecated TLS 1.0 and 1.1 last weekend. At least for plenty of my clients. Disable those protocols and SMTP starts working again on most machines, but all of the TA-xx00 and TA-xx50 machines won't work with O365, and need alternative SMTP.
                  • Ropariva
                    • 669
                    • tmaged
                      • Oct 2008
                      • 1880
                      We received a few calls today. 4803 is the error and it is intermittent. Does anyone know which models only support TLS 1.0 ?
                      I know the 0 series does. I contacted the hotline to see if they have any kind of list, which would be helpful. I'd like to make some instructions
                      for our techs, but it's kind of hard when you don't know what all models are afftected.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      • kilgan
                        • Oct 2021
                        • 3
                        for our techs, but it's kind of hard when you don't know what all models are affected.
                        I will say that I'm having the issue too.
                        Sadly, it happened just about the time I've upgraded our switches/re-ran ethernet *Upgraded from Cat 3 to 6* for the office. Everyone thinks it's because I did that. We utilize a TASKalfa 4501i in our office.
                        I've tried using all different versions of TLS available with my current software version. Still to no avail...
                        Very Frustrating. I'm looking for another email provider just for the printer and haven't found one yet that will work properly. Any suggestions?
                        Attached is my settings
                        My Firmware Ver:
                        System : 2N9_2000.004.505
                        Engine : 2N7_1000.004.002
                        Panel : 2N4_7000.004.501
                        Scanner : 2N4_1200.003.001
                        FAX : 3N6_5100.B06.001
                        • PrintWhisperer
                          • Feb 2018
                          • 471
                          ....We utilize a TASKalfa 4501i in our office.
                          OP was for an intermittent problem of unknown code and this thread has been sorta hijacked to the 4803 error but...
                          Thanks for posting the settings page for a '1' series so we can confirm at least it has TLS1.2
                          Try also disabling SHA1, ARCFOUR, and 3DES.
                          As previously noted ensure user (for SMTP auth) has 'SMTP send admin rights'
                          • jmaister
                            certified scrub
                            • Aug 2010
                            • 755
                            Hijack away. I was thinking along TLS as well.
                            Now sitting in front of a 4550ci having the same issue.
                              • 23006
                              We've got ONE KM-6052ci giving these 4803 scan to email errors ... among 16 others on the same network that do not have the errors.
                              The settings and firmware are entirely identical. The local IT intends on running a new drop and switching network ports. He hasn't tried it yet. As you might suspect, the errors are on about 1/2 of the scans, and it has absolutely nothing to do with the size of the document or the original scan settings.
                              If nobody has said so yet, the 4803 errors are failure to corroborate the SSL certificate on the customers server. =^..^=
