p3145 fuser problems out of box
  • tuey
    • Apr 2014
    • 120
    have a new p3145 that wont fuse a light card stock-wipe toner right off, machine is brand new. vendor wanted to try new fuser and sent a fk-3302 not the fk-3202 that i removed. is the fk-3202 on some sort of backorder status? the 3302 is for the p3055 but appears like it would fit but don't wanna screw up warranty. issue has been ongoing for 2 months and loosing patience. i ran the card stock through a p3045 i use in the warehouse and it fused just fine. getting almost zero help from vendor i was wondering if anyone here has had similar issue and could give me some direction-- too much effort for a $500printer. thanks--tuey
    • 23009
    Re: p3145 fuser problems out of box
    Have you tried changing to a heavier media type setting? What gsm is the "light card stock"? Does it have a gloss or texture? Have you used Plain paper? Does it fuse properly?
    Try the simple things first. =^..^=
    • tuey
      • Apr 2014
      • 120
      thanks but this has been going on for 2+ months. machine was purchased to do a bill run once a month. less than 1k prints. firmware, many tries at various throughput settings, kyocera apple drivers, every step that vendor wanted to try. i said a month ago it was probably gonna be fuser or a power supply. they said it was a new kyocera policy that is causing the 3 week lead time on a fuser. i've been begging for a DOA as it seems the quickest solution. they tell me that kyocera will reimburse me for our labor but that probably almost equals purchase price by now. anyone have any experience with labor reimbursement with them? are these issues being made worse by my vendor?? thanks--tuey
        • 23009
        Start with my questions, please.
        • tuey
          • Apr 2014
          • 120
          yes, don't know the gsm, texture, yes and yes. could have wrote very large paragraph on what i've tried--was trying to not make it too long. as i said, took the cardstock and ran it through my p3045 on 20lb and plain paper, fused perfectly. the vendor shipped me a fuser but it's for a 3155 (fk3302) and when i asked them for something in writing saying they would not void the warranty if i installed that instead of the fk3202 i got no reply. i've lost the sale after 2 months of dickin around so i'm just trying to get a good used p3145 that i could sell. as far as i'm concerned the fuser should have been sent a long time ago so i am laying most of the blame on my vendor and maybe kyocera. had i bought this from amazon the issue would have been taken care of 2 months ago-- and i'm not a huge amazon fan. thank-you-- tuey
          • PrintWhisperer
            • Feb 2018
            • 473
            302V393060 --> 302V393061 - FK-3202 P3145 do not put a different FK it won't help.
            Fuser revison is for wear between 150k and 350k and is not for any heating problem. Surface material changed to prevent wear of sep claws.
            Cassette spec weight limit is 120gsm, MP is 220gsm.
            If you cannot determine the GSM of your problem stock then there is no reason to assume it's supported.
            If you cannot set your media type properly then even supported paper isn't going to work.
            "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
              • 16416
              x100
                • 23009
                I'm surprised, frankly.
                You complain about a heavy media not fusing, but will not attempt media type changes, or even figure out what media weight it is? A person with over 30 years experience should know better.
                I don't think that I can be of any further assistance. =^..^=
                • tuey
                  • Apr 2014
                  • 120
                  trying all applicable paper options is the first thing i tried , even went back and tried it a second time and took notes so i could be sure i didn't miss any. then there was the firmware and making sure i was running the correct kyo drivers. all of this was done per the request of the vendors tech people. i am past that and into the troubleshooting for fuser or power supply issues-- again as per the instructions of the vendor. they control the warranty process so i do what they ask. my questions were A- are these fusers on backorder status as i was told it would take weeks to get one B what are the chances of getting a DOA on this machine as i've never had to do that before. C and how does the labor reimbursement thing work as i've never had to do that before and the vendor tells me this is possible. sorry for all the confusion- as a 30+ year printer tech i would never go on a forum and ask questions without fully trying to diagnose the problem. tuey
                  • PrintWhisperer
                    • Feb 2018
                    • 473
                    warrants to its Authorized Dealers12 monthsMaintenance Kits, lamps, exterior covers, consumable parts, and all labor costs, are specifically excluded from this warranty.
                    This warranty does not cover MFP/Printers, which: (a) have become damaged due to operator negligence, misuse, accidents, improper storage or unusual physical or electrical stress, (b) have used parts or supplies which are not genuine Kyocera brand parts or supplies, (c) have been installed or serviced by a technician not employed by Kyocera or an Authorized Kyocera Dealer, (d) have had the serial number modified, altered, or removed, or (e) Dealer fails to register the installation information for the MFP/Printer with Kyocera utilizing KMAconnect.
                    THIS WARRANTY IS MADE IN LIEU OF ALL OTHER WARRANTIES AND CONDITIONS, EXPRESS OR IMPLIED, AND KYOCERA SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OR CONDITION OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. THIS WARRANTY SHALL NOT EXTEND TO, AND KYOCERA SHALL NOT BE LIABLE FOR, ANY INCIDENTAL OR CONSEQUENTIAL DAMAGES WHICH MAY ARISE OUT OF THE USE OF, OR INABILITY TO USE, THE MFP/PRINTER.
                    • Samanator
                      • Sep 2017
                      • 579
                      I'm sorry, but what does that mean?
                      Did you try different media settings?
                      Did you use the heaviest media setting?
                      Did you run the heaviest media setting thru the MP tray?
                      Just trying to help.
                      • tuey
                        • Apr 2014
                        • 120
                        yes-exactly what i've done. this morning the fuser (correct one) arrived 2-3 weeks before i was told i would get it. i will install it and report back. still need answers to my original questions-- reimbursement for my labor and maybe doa procedure. thanks - tuey
                        • dalewb74
                          • Feb 2018
                          • 1157
                          if your replacements parts came from kyocera or whoever. contact them for your labor and etc......
                          • tuey
                            • Apr 2014
                            • 120
                            for history sake i thought i would update a little bit, been too busy archery hunting to get back here. happened to be going by the vendor for the cardstock they use for their bills and stopped in, took a while but they found the last order from them and the paper weight is 176 gsm, well within the 220 gsm maximum for the 2100 4100 3045 and 3145. i looked at my notes and i'd tried over 20 different media settings for bypass before i went a different direction. i've tried 2 different fusers and got different results with each one-both bad. going throught the process of getting warranty for the fusers now. second fuser has the weeping toner issue and wont fuser the cardstock either. tuey
