4103/4104 jam CS5052
  • McCrazy
    • Feb 2020
    • 15
  • avio2
    • Jul 2010
    • 150
    Re: 4103/4104 jam CS5052
    even if it's not that precise code
    J1403/J1404 Conveying sensor non-arrival
    jam
    Object: Paper feeder or Large capacity feeder
    Condition: There is a damage on paper. (Paper is
    caught. Conveying capability is decreasing. Or,
    paper is slipping.)
    jam
    Condition: There is no damage on paper. (Feed
    drive does not start. Or, conveying clutch does
    not operate correctly.)
    i think
      • 23007
      You might take a look at the sensor just past the second transfer roller. Which name do you like?:
      belt winding sensor
      belt wound sensor
      belt roll-up sensor
      PARTS SENSOR OPT. SP 303NW94060
      Yes, they are all the same single sensor. Kyocera just cannot seem to make up it's mind what to call it.
      No, actually, I understand that different teams of writers prepare different parts of the manual, and they don't always translate the same word, the same way.
      You can check the sensor operation in U031 [BELT SENSOR]. =^..^=
      • tsbservice
        Field tech
        • 8010
        belt winding sensor
        belt wound sensor
        belt roll-up sensor
        Sounds crazy stupid to me 😀
        You omit the middle part and end up with just belt sensor.
          • 23007
          LOL! =^..^=
          • PrintWhisperer
            • Feb 2018
            • 471
            Check for intermittent varying registration and go after the clutch Avio mentioned.
            "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
