Ecosys m3655 jam0105
  • newdente.gianluca
    • Feb 2016
    • 60
    [Error Code] Ecosys m3655 jam0105
    hi i have this machine with j0105 problem, can anyone help?
    i can ear the pressure releaser motor of the fuser unit always spinning, does not stop.
  • GIUBOSS
    • 1436
    Re: Ecosys m3655 jam0105
    Does the paper reach the registration roller?
    0105: Warm up request time out, fusing problem
    Scan and post the event log here if you can
    • newdente.gianluca
      • Feb 2016
      • 60
      Yes the paper reach the registration roller
      • BOYO
        • Jun 2021
        • 2
        The fix Replace PWB LV.
        • Step
          Senior Technician
          • Sep 2015
          • 42
          Good day
          I want to confirm if anyone can concur if replacing the PWB LV fixed the problem? Having the same issue on a machine that gave the error after client used machine on a generator.
          • KYO_OEM
            • Aug 2011
            • 721
            at first i would check fixing unit for broken gear.
