TASKalfa 7551ci colors go light after a few hundred copies
  • logrady2331
    • Feb 2011
    • 301
    Hello all,
    I have a TASKalfa 7551ci with 38k on it. Yes, not a typo, 38,000 total. We installed it last week and two days later the customer calls and says all three colors are super light/faded. We weren't sure of the health of the developers so we ordered the color MA kit and also replaced the t-belt while we were at it. It set up just like it should with the new PM kit and t-belt. Two days later our tech went to the customer for a follow up and all three colors are super light AGAIN. It never asks for color toner and to my knowledge doesn't present any error codes. Any thoughts? I am leaning toward main or engine pcb but wanted to see of anyone has seen it before. Thanks in advance for any suggestions.
    • 22997
    Re: TASKalfa 7551ci colors go light after a few hundred copies
    What simulations did you do?
    Do you have any samples? Try something like this:
    • logrady2331
      • Feb 2011
      • 301
      Hi Blackcat,
      Thanks for the response. We cleaned the ID sensors of course, ran 140, and 119, 465,469 and 410. Color density returns to normal after dev refresh and calibration in user tools. It never asks for toner. Black is fine, never goes light. It is plain to see it isn't adding toner as CQ comes back after a refresh. Dev units are brand new so I am ruling out toner sensors.
      • logrady2331
        • Feb 2011
        • 301
        Blackcat, My senior tech tells me ALL colors are affected. Sorry about that. I know that changes the approach. He can run sim 131 and the voltages/toner sensor levels return to normal. No error codes at all. Never asks for toner.
        • dalewb74
          • Feb 2018
          • 1125
          optics are clean? genuine kyocera parts?
          • PrintWhisperer
            • Feb 2018
            • 465
            Check the customer power for sags and Neutral to Ground faults.
            Even though it comes with 2 Nema 5-15R power cords, this machine requires a DEDICATED 20 AMP circuit.
            The hi-volume frames are power hungry and don't like to share.
            If the power droops during a calibration it could throw it off like that.
            "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
              • 22997
              ... and those samples? =^..^=
                  Oops. The above procedure was for a different model. This is for your model.
                  Check U468 V-Correction value.
                  Good value/ sucessfully running last 16
                  calibrations = 65535
                  Decimal: 65535
                  Binary: 1111.1111.1111.1111
                  (each “1“ = sucessfully calibration)
                  For checking, use scientifical setting from calculator
                  Additional you can check Eventlog for
                  C7601-front ID sensor error
                  C7602-rear ID sensor error
                  (C76xx won`t shown on operation screen)
                  For checking surface from Transferbelt
                  U465/ Stress must be between
                  2200 - 2900
                  KYO_OEM taught me how to check the last 16 calibrations to see if they passed/failed.
                  • Ropariva
                    • 652
                    Have you tried swapping K drum to M or C before a refresh to see if the issue moves with the drum?
                    • fishleg
                      • Mar 2009
                      • 426
                      Does it slowly fade or is it bam faded prints? If it slowly fades then I think you've got a toner adding problem. I had one where the customer prints a lot of high coverage setting calibration to short seemed to help massively. I also set u325 to mode 2 which someone on here suggested again helped.
                      I think theres a fault with kyo and certain coverage on the faster engines. I've seen a few with high coverage do it on the 52 53 series. Need some 089 test prints posting on here so we can help better.
                        I believe blackcat asked for test prints twice and now this is the 3rd time someone has asked. The OP need to make it happen.
                        • logrady2331
                          • Feb 2011
                          • 301
                          • logrady2331
                            • Feb 2011
                            • 301
                            Sorry for the typo. I meant main board.
