Tasklafa 5501i scaner
  • Gab
    • Aug 2015
    • 671
    i want this machine to scan . i have done it several times but now i fail with same set up as previous machines . I have connected a laptop to copier can anybody tell how to set up command center?
  • dantab1980
    DanTab
    • May 2015
    • 16
    Re: Tasklafa 5501i scaner
    You need to add Pinpoint Scan software. It's a licenced software.
    • Ropariva
      • 674
      Scan to?
      Email, SMB,FTP???
      Pinpoint scan not necessary though some swear by it
      Kyocera have a SMB tool on their downloads, easy to use
      I use FTP with FileZilla, more difficult but less likely to get broken.
      It will authenticate TLS1.1 so email/office 365 or Gmail is possible.
        • 16391
        you better be sure that you have the latest firmware.
        • PrintWhisperer
          • Feb 2018
          • 471
          Yep, pre v5 firmware SMB2 is broken.
          "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
            • 30216
            The site also has scan via email setup as well
            • PrintWhisperer
              • Feb 2018
              • 471
              Not a bad video for a user, but it presumes that DNS has been set-up correctly.
              It also demonstrates poor administration in that Servers are for sharing, not workstations. Too many passwords and too little security.
                • 30216
                I am sure it will help someone out Basic install for Kyocera
                • copier tech
                  • 8144
                  Update the firmware then try a scan again.
                  • dalewb74
                    • Feb 2018
                    • 1153
                    do a google search for kyocera print center. it will download from the microsoft store. simple straight forward setup, if you are familiar with setting up scanning. i believe it's a dressed up twain scan driver.
