Taskalfa XX52ci replace toner message after toner replaced
  • drazen7777
    • Sep 2010
    • 40
    [Misc] Taskalfa XX52ci replace toner message after toner replaced
    Hy to all
    I am curious does anyone have permanent solution for replace toner message on device after toner has been replaced. But problem is somewhere in interlock switch because after front door and side door reseated problem is gone. I think i saw service bulletin in the past to change mount interlock and arm interlock but now i cant find anything about it in Kyocera extranet.
    I have lots of customers that change toner by them selfs and every often they got this message and they are bit annoyed by that. Did anyone find workaround maybe?
    Best regards
    Drazen
    Technician -- a person who fixes the mistakes made by engineers.
    • 22981
    Re: Taskalfa XX52ci replace toner message after toner replaced
    Have you looked at existing threads:
    KM-5052ci, "Add Black Toner" when images are over 5% fill
      I remember that thread. I'll say the same thing: That was a good find and it was a fun read.
      • tmaged
        Owner/Service Manager
        • 1864
        H159 is the bulletin number. The part numbers are 302ND04321 & 302ND29621.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • drazen7777
          • Sep 2010
          • 40
          Yes ,thats the one (searched several times through the bulletins but missed it every time), thanks. I probably missed it because name of the bulletin (Corrective measures for displaying the lower front cover open) the message that the cover is open is not shown on display. I think the reason is because replace toner message is shown at that moment on display , toner was replaced but device did not get signal that toner is replaced because cover is open but not shown on display and not visible physically that cover is open. When you open and close front cover and right cover interlock switch reseats at his place device comes to ready and registers toner change and continues to work normally.
          Did you try or do the replacement , is it time consuming?
          • drazen7777
            • Sep 2010
            • 40
            Yes i saw it , good find, but that is not the case i have , thanks for reply , tmaged pointed to me and i described it in post above.
            • tmaged
              • 1864
              Not long at all. Should take about 10 minutes.
              Hope that helps !
              -Tony
              www.dtios.com
              • ThisPete
                Too old to care
                • Jun 2014
                • 153
                You can just bend the arm on the microswitch to make it 'operate earlier' rather than ordering parts and having to go back there again.. using a pair of pliers bend the metal lever just after the switch actuating button (side away from the pivot), I've done it several times now.
