Ecosys P2040 How do I print an Event Log ?
  • Doug James
    • Jan 2012
    • 935
    [Jamming] Ecosys P2040 How do I print an Event Log ?
    I have this printer on warranty and it started intermittent jamming at 50,000 copies. I am having troubleshooting it and am needing to print the event log. In the service manual it says to input a code but not sure at all what it is talking about. Been a tech for 30 years... The jamming is occurring as soon as it enters the fuser, then the paper stops. No paper wrinkling. I replaced the printer with a new one to bring the problem printer to my shop to fix. Now the customer says it is happening on the new printer (Jamming)... Any help would be very appreciated
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1867
    Re: Ecosys P2040 How do I print an Event Log ?
    More than likely needs a fuser. There are a couple of ways to do it. Through the prescribe command on a flash drive is one. That's a little difficult if you're not tech saavy. The other way is to look at it, by putting it on the network and going to the web page at xxx.xxx.xxx.xxx/svcmntrpt
    This will display the log. If it's on KFS, you can also view the log there.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 29830
      If the other printer is doing it also what kind of paper is the customer using? Also check paper size settings
      Paper size and or media type will see jamming if not set correctly.
        • 22997
        Try this:
        https://www.copytechnet.com/forums/k...ml#post1786175
        • JR2ALTA
          • Feb 2010
          • 2030
          Was the second printer new or used? You'll get these jams anywhere from 20k onward. My bet is the fuser, the jam code to confirm this is j4211.
          • copier tech
            • 8131
            If you installed a new P2040 & this also jams most likely user error or a totally different jamming issue, poor quality/damp paper for example.
            โ€‹
            • Ropariva
              • 647
              Do you have IC Link? Send the PRESCIBE event log command thru that
              Or web interface IP/EVENTLOG
              • lanierboy
                • 149
                event log.zip
                Try the attached file,
                unzip and copy the .capt file to a USB pendrive, Place in the printer usb slot and select print from usb, the event file will be printed
                • Doug James
                  • Jan 2012
                  • 935
                  The one I replace the new one with has 4000 copies on it.
                  • Doug James
                    • Jan 2012
                    • 935
                    Yep 4211, Not sure if I want to change the fuser every 50K. Surprised Kyocera has a low quality fuser.
                    • Doug James
                      • Jan 2012
                      • 935
                      Sure do appreciate all the comments. Means more than you know THANKS !!!!!
                        • 22997
                        Some of our techs have been removing the teflon strip, then using fuser sleeve grease on the remaining surface. I cannot comment on the resulting yield, but it doesn't cost you but 30 minutes and a dab of grease to try. =^..^=
