ecosys 6525
  • Gab
    • Aug 2015
    • 655
    ecosys 6525
    copy image is fade . When i turn on machine it tries to load toner. MAchine has made about 100k copies . Any idea?
    Also if i replace developer unit what programs to execute?
    • 22927
    Is the machine in a high humidity environment? This looks like condensation on the drum. In the short tern a drum refresh may remove that condensation. If the environment stays humid it will be an ongoing issue.
    If you choose to replace the developing unit, there is an instruction sheet telling you exactly what you must do during the developing unit replacement, right in the box with the new part.
    • subaro
      • Oct 2010
      • 1273
      remove all the drums, and devs. Clean the laser glass, they get dirty . Sometimes they get condesation or dirt inside the laser mirrors. Could be cleaned, but you have to use your wits to clean them. Then run the drum/dev refresh and finally the calibration.
      • jewen25
        • Mar 2009
        • 194
        Try sim 130
        ERROR HELP ME AND HELP YOU
        • Lunatech
          • Oct 2012
          • 177
          Originally posted by jewen25
          Try sim 130
          Huh. I thought it was sim 140.
          • Gab
            • Aug 2015
            • 655
            Suddenly it made some quality copies but next day the same. Noticed that when there is a smell from copier when this fade copy occures.
            • Larhal
              Semi Retired
              • 532
              Sound like there is a weak connection from one of the boards.
              Larhal
              Retired Part Time
              If all else fails read the Service Manual!
              If that fails, meet me at the pub and we will discuss it.
              • ntbann
                • Jan 2012
                • 622
                If you push in on the right hand cover does it make a good print. Had one that the clips to hold in the HVPWB were broken causing something like what you have.
