Kyocera 3645 not grabbing an IP address.
  • PrintWhisperer
    • Feb 2018
    • 471
    #31
    Re: Kyocera 3645 not grabbing an IP address.
    Your All-in-One Learning Portal: GeeksforGeeks is a comprehensive educational platform that empowers learners across domains-spanning computer science and programming, school education, upskilling, commerce, software tools, competitive exams, and more.
    Wireshark it
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
    • Necrocannibal
      • May 2008
      • 212
      #32
      Update for everyone. Went back and played around with it and changing the speed from Auto to 100base-t fixed the issue, even though the Auto was picking that anyway. Really odd and I've never seen that harken before.
      Sent from my SM-N986U using Tapatalk
      • tsbservice
        Field tech
        • 8008
        #33
        Great, tmaged advice.
        • Necrocannibal
          • May 2008
          • 212
          #34
          Yep, spot on.
            • 16385
            #35
            I'll have to file this one away just in case I ever run into it. I'm still a little surprised that it would grab a DHCP address when you moved it to a different location (port). Oh well, chalk it up to magic and move on.....
            • Necrocannibal
              • May 2008
              • 212
              #36
              Lol, basically, makes no sense whatsoever to me.
              • Samanator
                • Sep 2017
                • 579
                #37
                I have experienced this type of thing before. It started when smart switches started showing up out in the field.
                For some reason a particular nic card on a device will not negotiate with the smart switch when the nic card is set to auto. Setting the nic card to a fixed speed stops the negotiating processes and things work.
                I have experienced this with different devices in different locations. Not very often, but it does happen.
                  • 16385
                  #38
                  The only similar instance I've seen is that the NIC appeared to be frozen and switching between auto and the manual settings got it to working again.
                  This particular problem is just weird because the machine worked fine on a different port on the same switch. If anyone can solve that riddle, I'm all ears. lol
                  • darry1322
                    • Oct 2010
                    • 817
                    #39
                    Only thing different is the network drop. I've had a couple customer replace the drop and resolve this particular issue.
                    • Gab
                      • Aug 2015
                      • 671
                      #40
                      check on controller the jack that cable from network attached to copier perhaps someone pull it out violently and the pins have bended. tha jack
                      • Necrocannibal
                        • May 2008
                        • 212
                        #41
                        The machine has been working fine since I switched the network speed to 100Base-t over Auto even though Auto choose 100Base-t.
