Copystar CS 3050ci Jam 0000 error please help..
  • mprivi
    • Jan 2022
    • 13
    #16
    Re: Copystar CS 3050ci Jam 0000 error please help..
    Originally posted by Ropariva
    Your secondary transfer release casing is broken. That is quite a job to replace. The other issue was likely paper dust. The area circled in the pic should be black as this backs up the sensor in the machine.
    I see. To have gotten the jam 0000 error fixed and was able to print stuff but now it makes like a grinding noise and a Machine failure C2730 where is the secondary transfer release casing ? Is there a part number or a walk through?
    • Ropariva
      • 663
      #17
      • mprivi
        • Jan 2022
        • 13
        #18
        • mprivi
          • Jan 2022
          • 13
          #19
          Is this the piece that needs to be replaced?
          • ntbann
            • Jan 2012
            • 628
            #20
            Yes there is a weak gear pin that breaks. Not fun!
            • Ropariva
              • 663
              #21
                You being an end user needs to hire a trained tech.
                We techs have trained on equipment for decades to get to this level.
                End users THINK they can do our jobs.
                Bet you don't have a service manual.
                • mprivi
                  • Jan 2022
                  • 13
                  #23
                  I'm sure it's a detailed complicated repair from the looks of the diagram, but thank you for the inspirational words. I also do have a copy of the Service Manual.
                  • mprivi
                    • Jan 2022
                    • 13
                    #24
                    Thanks for the help... any pointers on tackling this repair?
                      • 23006
                      #25
                      If you've got this far, you're through the worst of it. There's a lot of spring tension on the secondary transfer unit.
                      When you're assembling leave the springs for last. The springs will insert through a slot at the front and back, after the transfer unit is secure. =^..^=
                      • Samanator
                        • Sep 2017
                        • 577
                        #26
                        If you decide to replace the whole right side door, only use a right side door from a 3050ci or a 3550ci. Although the part (302K924782 Drive Release Housing) is the same inside the door on the 3050ci,3550ci,4550ci,5550ci, the right side doors are different on the 4550ci and 5550ci.
                        I have replaced the Drive Release Housing a few time and its not all that hard, just a bit of a pain in the ass the first time.
                        If you keep any of these models (3050ci,3550ci,4550ci,5550ci,3051ci,3551ci,4551ci, 5551ci) out in the field for a while, you will run into this problem. Not a matter of if, just a matter of when.
                        • mprivi
                          • Jan 2022
                          • 13
                          #27
                          Ok...... So i changed the housing part # 302K924782 Drive Release Housing... my housing looked fine. I still get the error and the noise. Can it be something in the housing? Everything looked good. Not sure if i should all new pieces inside the housing.
                            • 23006
                            #28
                            Were any of the gears damaged? That would have been a good time to look ... when it was apart. =^..^=
