356ci faint cyan
  • mntech
    • Aug 2010
    • 250
    [CQ] 356ci faint cyan
    Hello tech community,
    I have a kyocera 356ci giving me hell. They cyan is very washed out and is causing colors to not look right.
    I have replaced the Dev, Drum, Transfer Belt, and Laser Unit with no luck. (from a good working machine we have at our shop)
    Tried dev refresh, calibrations, half tone adjust fails. Even tried monkeying with the bias voltages in service. No luck.
    Ill attach some examples, let me know if you have any ideas. On the U089 chart the large cyan box is visible on the page, but wouldn't scan, just very faint.
    Thanks,
    -MNTech
    356ci.pdf
  • tsbservice
    Field tech
    • 8020
    Re: 356ci faint cyan
    You've replaced almost everything but high voltage unit. Hopefully Kyo techs will come with more ideas.
      • 23009
      Have you tried an emergency stop, then viewing the latent developed images on the transfer belt, and on the drum?
      I'm going to guess that you've got a good latent image on the cyan drum, but it's incomplete primary transfer. There may be something wrong with the primary transfer roller mechanics, the HVT or the main board. =^..^=
      • KYO_OEM
        • Aug 2011
        • 720
        check HV contact from belt.
        Have had similar problem with magenta in past.
        • copiertec
          • Jan 2016
          • 2211
          Ditto of what KYO OEM posted, I ran into the same issue about 2 weeks ago, copies and prints were fine before I removed the transfer belt to clean because of toner drops on the paper. Reinstalled the belt and had an issue with black copies afterwards. Then I noticed the contact for the black was out of place, realigned it and all was good.
          • taskalfaman
            • Nov 2009
            • 137
            most likely spring insite the device which is out position due to removal of old Transfer belt.
            If you measure you will know. Normally you should see it also visually.
            have fun.
            • sparkycivic
              • Apr 2017
              • 348
              I had this on yellow that took me wayyy too long to notice that the spring at the rear of the machine for the transfer belt (Y) was stuck retracted and twisted in it's little slot, very hard to see.
              I wasted a new developer, drum, transfer belt, and many hours messing around with it.
