kyocera taskalfa 7052ci blurred image in printing + copying
  • rickirobert
    • Mar 2019
    • 32
    Hello everyone ,
    I have a copier that prints blurred footers in A4 portrait
    look at the attached documents
    the LSU has been changed but the problem is the same
    the machine is up to date for the firmware
    I recalibrated it
    for the black it s ok, but yellow, magenta, cyan no
    if you have an idea ? thank you
  • sparkycivic
    • Apr 2017
    • 348
    Re: kyocera taskalfa 7052ci blurred image in printing + copying
    can you show us a U89 sample set?
    is the problem uniform across the page or limited to an area?
    has the transfer belt been removed/inspected/re-inserted?
    life of drums/MK?
    any C-codes stored?
    • rickirobert
      • Mar 2019
      • 32
      here are the u89s
      the TR has been changed to a new one and the problem is the same.
      it is only the bottom of the page which is blurred on 2 3 cm
      Thanks for your help
        • 23009
        Has that laser been disassembled and mirrors cleaned?
        I've done this to myself before. In a dirty environment the mirrors, lenses, and polygon mirror motor can get very dusty. In the process of cleaning the mirrors, it's sometimes necessary to remove one mirror to access others. These are all front surface mirrors, and I have inadvertently installed one of the mirrors reversed, creating a very subtle double image: reflection & refraction. =^..^=
        • rickirobert
          • Mar 2019
          • 32
          hello
          I had changed the Magenta LSU laser with a new one and the problem is identical, cloudy image and white band.
          I wonder if I should not put a ferrite around the cables that connect to the lasers ?
          • sabbish
            • Apr 2022
            • 8
            • fishleg
              • Mar 2009
              • 426
              It's a faff but I'd be taking the Devs to another machine or replace the worse one just to see if issue improves.
              It's different on every colour so I'd be concentrating on Devs after ruling out belt & lasers. Drum issue would cause dark image.
              • ThisPete
                Too old to care
                • Jun 2014
                • 215
                I'd be looking at cleaning up that end of the mag rollers, KM3050's and 3035's used to do it and I have seen it on more recent machines too, sometimes a clean sorts it, sometimes it comes back and a new dev unit is required.
                • tee
                  • Aug 2014
                  • 79
                  Is there any toner spilling from that side of the machine?
                  It looks like a drum/charge issue or possibly 2nd transfer if the
                  polygon motor mirrors are pristine on the tips.
                  • Rpizzle
                    • Mar 2014
                    • 47
                    I would have to agree with fish up there, used to have 3050cis do this all the time.
                    • Ropariva
                      • 680
                      Originally posted by rickirobert
                      Hello everyone ,
                      I recalibrated it
                      • pascalb.
                        • Aug 2016
                        • 47
                        hello,
                        Maybe the lasers should be reset?
                        U467 / Color Regist switch to Off
                        switch off /on, the machine.
                        return to U467 / Color Regist reset to On
                        then do a Color Registration manual in System menu.
                        good luck.
                        Do not lament,
                        do not mock,
                        do not hate,
                        but understand.
                        • PrintWhisperer
                          • Feb 2018
                          • 473
                          Originally posted by pascalb.
                          hello,
                          good luck.
                          Winner winner chicken dinner, nice recall.
                          First time seeing this on a "2" series (many '3' series Hi-volume have had this problem). In MM467 it's 'Auto Color Regist' and it gets scrambled data so the above will reset the values.
                          Remember all colors reference black base value so black isn't affected.
                          "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
                          • rickirobert
                            • Mar 2019
                            • 32
                            Hi all,
                            I thank Pascal who knows these machines perfectly and following his precious help everything is ok
