Kyocera M3540idn Jam 501
  • copykat93
    • Oct 2021
    • 281
    Hi guys, I have a customer's machine, M3540idn, has one additional drawer...machine has just under 400K on it, had had the maint kit done at 300K... Machine will throw jam 501 error from top drawer only, it doesn't matter if you are making 1 copy or 5 copies, it mite work 2 times out of 5 and it mite jam with 1 copy, then the next time it will make 3 and jam, then it mite do 10 then jam... I replaced the feed rollers, sep roller & even tried 14" from top drawer & still same outcome. bottom drawer is great, top is the issue, by-pass tray works great ... Any help appreciated
    • 23009
    Re: Kyocera M3540idn Jam 501
    Is the pickup spring still there? Often that spring disappears ... especially after a roller change. =^..^=
    • piksel1983
      • Oct 2018
      • 38
      M3540idn Has no spring as i remember
      Wysłane z mojego Mi 9 SE przy użyciu Tapatalka
      • spw
        • Mar 2015
        • 62
        i believe the 3540 and the printer version(2100) are fixed without the spring.
        did the 501 jams happen before the kit or only after?
        • copykat93
          • Oct 2021
          • 281
          The jams just started on Friday with the customer, the maint kit was done months ago... The M3540 doesn't have a spring for the feed roller assy in the upper drawer.. The additional drawer has the spring, but not the upper standard drawer.
          I did replace the feed roller assy today and also the sep roller in the drawer, but that did not help
          • spw
            • Mar 2015
            • 62
            ssounds like the clutch pack on the right side of the machine that drives feed. they usually go out around the count that you gave
            They arent too bad to put in
            its called "Parts drive feed assembly" its a pack. Has 2 clutches and a solenoid on it. Part number for the 42 ppm is 302MS94051 i believe. super easy to put in
              Check the paper stopper in the cassette, see the pdf.
              SB-2LV-0052-F033_.1.pdf
              • Ropariva
                • 680
                • copykat93
                  • Oct 2021
                  • 281
                  I'm not gonna argue, but there is no spring in the feed assy for the m3540, I have 2 in my shop that have under 40k on them and neither one has the spring in the feed unit, the feed assy actually fits right up against the upper metal frame that it clips in to and there is no movement from the feed assy.... If there was movement I would say to add a spring for down pressure, but no movement at all from the feed assy.
                  • Luther
                    • May 2006
                    • 682
                    There is no spring in the 40ppm only the 50 and 60ppm both have the lift motor, agree with previous post to change the clutch pack
                    • tmaged
                      Owner/Service Manager
                      • Oct 2008
                      • 1888
                      G081.pdf
                      According to G081 the spring is not on the 40ppm.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      Become a fan on Facebook
                      • spw
                        • Mar 2015
                        • 62
                        That 2nd bulletin you posted shows its just for the higher speed machines .The assembly is the same for both ,the spring with a hook attached to the underside is the upgraded mod for the 3550/3560 models of the assembly( the spring would fall off when switching rollers out all the time. We have a bag of them here just for that purpose before the hook modded spring came out. As mentioned by the others the 3550/3560 models have a lift motor and a gear in tray 1 so a need for a pressure spring.
                        The 3540 model has a spring loaded tray so no need for a spring. It would be too much pressure to feed consistent. Its the same thing as a 2100 printer version model. No springs in those either. We have worked on dozens and dozens of all 3 models. Never seen a 3540 with a spring.
                        • kjg
                          • Mar 2009
                          • 112
                          Lots of responses on this one.
                          I would agree to look at the clutch pack for feed. Replacement is not difficult. (was mentioned also - its a different number than higher speed models).
                          I own a 3540 and it has no spring on the top of the feed head for tray 1. They have lift springs in the cassette so its unnecessary.
                          You could certainly put one in if you want I suppose. But not really necessary.
                          Higher speed models need the spring since they use a lift motor as opposed to springs.
                          Best wishes.
