TaskAlfa 4002i/C9040 Error
    • 16374
    I received this service call right before closing and will be going on location in the morning. I know this is a DP lift plate/motor problem but have never seen this problem before. What's the most likey cause so that I can be sure to take what I need?
    Thanks.
  • Luther
    • May 2006
    • 682
    Re: TaskAlfa 4002i/C9040 Error
    It's more then likely going to be disabled when you get there, do a 906 and try the DP, if the plate does not lift or it codes again it's going to be the DP board , replaced 5 or 6 for the same issue
      • 16374
      Thanks, Luther. Much appreciated.
        • 23006
        You may also find that the plastic swivel point for the lift place is broken at the rear.
        • JR2ALTA
          • Feb 2010
          • 2033
          Thanks.
          hopefully customer had a foreign object on the lift plate and you can 906 it.
          • KYO_OEM
            • Aug 2011
            • 711
            Hi Billy,
            see attachment
              • 16374
              Originally posted by KYO_OEM
              Hi Billy,
              see attachment
              As always, thanks, KYO.
                • 23006
                Thanks KYO, that's what I was talking about. =^..^=
                  • 16374
                  I knew exactly what you were talking about from your description and that's what it was. I replaced with a used part but I'm gonna order some of the updated parts from KYO's bulletin.
                  Thanks to everyone for your help. This site has never let me down.
                  • Samanator
                    • Sep 2017
                    • 577
                    After I saw that, I thought that's quite a thing to say because for me as well, this site has never let me down.
                    And that says volumes about a bunch of folks sharing information for no other reason than to help one another solve problems.
                    Just thought I'd throw that out.
                      • 16374
                      The used lift plate that I installed in the customers machine lasted about a week and it too broke @ rear post. Fortunately, I ordered a few of the updated (thanks KYO) lift plates with the metal post.
                        • 23006
                        If you're thinking of MacGuyvering it, it's not worth the time. It took me an additional hour to drill through the plastic shaft, insert a metal shaft, and epoxy it in place. It was a permanent fix, but kind-of a long call with the additional disassembly/reassembly.
                          • 16374
                          That sounds kinda fun but, no, I wasn't thinking about modding the lift plate. What I was trying to say is that my new updated liftgates arrived today via Fedex and they have a steel shaft as opposed to the plastic one that keeps breaking.
