TASKalfa 4052ci- fusing unit
  • RandyW
    • Jan 2013
    • 213
    Checking if parts are available for the fuser units.
    Looking at the parts book I have it just shows the whole fuser unit.
    thanks
    • 23010
    Re: TASKalfa 4052ci- fusing unit
    That's it, the assembly, and it's been updated a dozen times. Will they get all the bugs out of it? I suspect yes, eventually. =^..^=
    • Larhal
      • 612
      And don't forget the "rust".
      Larhal
      If all else fails read the Service Manual!
      If that fails, meet me at the pub and we will discuss it.
      • RandyW
        • Jan 2013
        • 213
        Do those machines have problems scanning? Working than not working?
        I told our account there's not much we could check for that and they should call their IT people.
        • davidmtupper
          • Jul 2021
          • 326
          Yup, start seeing that and get ready to replace the fuser. It WILL start throwing 6600 codes soon.
          • sparkycivic
            • Apr 2017
            • 348
            Once the rust runs out, c6600 'low rust level' is achieved.
            I tore a rusty one down, it was the bearings spinning on the shaft of the press roller, grinding it down and creating the rust, mixed with the dried grease from inside the sealed bearing units.
            Too bad they are press-fit and with only a clip to keep them located longitudinally. I'm sure the temperature swings work against keeping the inner-race seated on the plain shaft allowing them to spin, but then again the bearings are overheated and dried out anyhow. lots of design issues regarding that...
