Kyocera 2540 got me worried.
  • allan
    RTFM!!
    • 5462
    No I am not lost. Actually moving my interest to Kyocera as I am getting calls on them from a company with mostly Konica Minolta.
    Found the waste container in the front of the drum unit stuffed I made a hole on the top in the middle, emptied it and covered it with the warning sticker. 3de party toner... The DF separation assy shot and double feeding J9001 I think pulled the white rubber pad off an glued it back .5mm higher and that fixed that. The tray separation roller bald and double feeding from time to time, I pulled the rubbers of and changed the feed, separation and pickup rubbers around to get that to work. The worst is the fuser film belt was too tight due to no lubrication? J4211 I think. That all at 40K prints!?? And these were out of the box not long ago.
    I ordered the separation assy(super expensive costing the same as an original toner for a plastic thingy), a set of tray rollers and a fuser out on warranty claim.
    Any thing else these little machines can throw at you this earl in the race?
    The 1128 and 1135 did not have these issues if I recall. I like those a lot. This makes me worried.
    Whatever
  • tmaged
    Owner/Service Manager
    • 1868
    Re: Kyocera 2540 got me worried.
    Fuser is the only issue we have with them.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 22997
      Originally posted by allan
      ... Found the waste container in the front of the drum unit stuffed I made a hole on the top in the middle, emptied it and covered it with the warning sticker. 3de party toner...
      Yeah, 3rd party toner is NOT a good thing on mono-component Kyoceras.
      ... The DF separation assy shot and double feeding J9001 I think pulled the white rubber pad off an glued it back .5mm higher and that fixed that. The tray separation roller bald and double feeding from time to time, I pulled the rubbers of and changed the feed, separation and pickup rubbers around to get that to work ...
      All expected, normal.
      ... The worst is the fuser film belt was too tight due to no lubrication? J4211 I think. That all at 40K prints!?? And these were out of the box not long ago ... and a fuser out on warranty claim ...
      Again normal, 40K means that they run standard 75gsm plain paper, light fill. If they start running heavier media or heavier fill, the fuser won't last even that long. Read the threads about removing the teflon sheet, and re-lubricating with a different lubricant. I have not tried it (since we get warranty) but I have heard of successes. If you have toner buildup on the fuser film surface you can also gain some time in-between by running a PreScribe command cleaning function. See attached:
      https://www.copytechnet.com/forums/k...ml#post2160612
      ... Anything else these little machines can throw at you this early in the race?
      No, that's about it. You won't like the Libra & Polaris as much.
      Don't worry, be happy. =^..^=
      • copykat93
        • Oct 2021
        • 272
        YEP!!... The fuser is the worst thing to worry about... In my opinion I would just replace the fuser instead of rebuilding (PIA to rebuild) once you replace the fuser, turn the timers on and set at 5 minutes or less.. the fuser seems to last longer when the machine isn't sitting there baking itself to death. Customer may complain about the wait time for it to warm up, but it is the lesser of the 2 evils. It will save on the drum life as well when the timers are set low. And even from a cold start, the machine takes less than 20 seconds till its ready to go. Hope this helps
        On a side not, again, just my opinion. Kyocera machines don't run as well with compatible toner, drum life will be shorter too, Cleaning issues, overtoning issues too.
        • davidmtupper
          • Jul 2021
          • 326
          If the waste toner was full the drum and developer are likely nearing end of life as well, just something to keep in mind.
          • allan
            RTFM!!
            • 5462
            Thank you if it only that than it should be ok. I am used to those brother 8880 DN style machine(aka bizhub B20) for A4 and those are awesome. You forget that it uses a fuser... Sure I had machines with 500K on them with the original fuser still working.
            Apologies if you have mention in other post what lubricant you find useful on those film type fusers?
            Whatever
            • dalewb74
              • Feb 2018
              • 1125
              no saying it doesn't help, or won't work. but i have never in all my years put any kind of lubricate on a kyocera, or any other brands fuser.
              • tmaged
                • 1868
                Warranty them until you can't, then rebuild them following some of the threads on here. Remove the teflon sliding sheet.
                Hope that helps !
                -Tony
                www.dtios.com
                • allan
                  RTFM!!
                  • 5462
                  I am independent and get them ex-lease. Then ones I can claim for are for companies I do freelance calls for. That is on there contract machines.
                  The 2540 machines I can get for cheap but no good if the fusers don't last so I need a way to make them work.
                  Or like BC mentioned to keep them running in the time it takes to get the replacement.
                  Whatever
                    • 22997
                    This is what they use in the YouTube video "Electrolube Fuser Film Lubricant":
                    AFC400D by ELECTROLUBE - Buy or Repair at Radwell
                    - Radwell.com
                    I don't have a personal endorsement. I was leaning towards the OIL-965 used on the Toshiba eS4555C film fusers. Never having tried it, I can't say whether it would work or not. AFAIK there is no part number for the Toshiba silicon oil. It just comes as part of the fuser kit.
                    Here's the YouTube video:
                    Kyocera P2235dn, M2040dn fuser repair. - YouTube
                    Good luck! And please post back your results. =^..^=
                    • tmaged
                      • 1868
                      I wish they would quit trying to over engineer fusing units. Almost every segment has some type of fusing unit issues when released.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                        • 22997
                        Fuser issues have been around as long as I have (... hey, do you think it's something to do with me?!). When they took a Mita DC-1655 and tried to ramp it up to 30cpm (DC-3055) the plastic bushing tore themselves to shreds almost immediately (1992?)
                        Every new fuser design has brought along it's own heartache, since they left the old-fashioned teflon coated aluminum rollers behind. The bugs seem to get hard & harder to resolve. =^..^=
                        • allan
                          RTFM!!
                          • 5462
                          - Radwell.com
                          Thank you.
                          Expensive stuff. But the right article.
                          15watt laser could fuser toner through a film sleeve? And would have no warmup time at all and yea 15watt!! It will scan like a PH.
                          Whatever
                          • allan
                            RTFM!!
                            • 5462
                            Wonder if this is any good. Chemplex 710.
                            GREASE FOR FUSER FILM SLEEVE INSTALLATION CHEMPLEX 710 HP LEXMARK CANON DELL USA 723794399012 | eBay
                            Whatever
                              • 22997
                              I don't know if it's the same stuff I used back when ... but Chemplex was horrible!! It would smoke and stink .. and kept smoking and stinking for weeks afterwards. We used it on the bicycle chain fuser drive Torrington's on the Mita DC-5055. It was the only thing we had at the time, and stunk up every office we used it in. =^..^=
